You can go with with up to a 28 with out modding the car to make them fit to much. Its more about gear ratio when factoring in tire height than anything. You want to cross the traps in 4th gear at the peak RPM your car makes power.
o i have a set of motive 4.10s waiting to be installed if that helps. i want as big as a tire i can get in the back with out pounding anything and a tire in the front i can DD on if i want. prob no smaller then a 235
Well again it depends on how fast you think your car is going to go in the 1/4.
You might not have enough tire/gear with a 26 to hit the kind of mph you're looking for without having to shift into 5th or hitting the limiter in 4th. Which is a reason to go up to a 27 or 28.
A larger tire like a 28 can slow you down if you don't need it tho.
The smaller tire you can effectively run the faster your car is going to be as long as you can hook it.
him some food for thought. maybe going with a 27 wouldnt be so bad. that way i ensure a little more but dont take away to much ?
Play with that for a little bit as it should give you a rough estimate or what size tire your going to need with what gears and RPM you are planning on running in the car
what kind of tire are you looking at?
I used to run 27/10.5/15 et streets and they fit perfect. the 28's required some work.
I went 1.45 60ft on all these tires
26/11.50.16 et street
27/10.50/15 et street
28/10.50s/15 et drags
ya i like the way it looks. i have 275s now, happy with them. what size rim would i need for a 275, u say 10inch is to big?
I'm not saying it is to big because it will work.
What I'm trying to say is a 275 is really all you're going to need. And with only running a 275 tire an 8in wheel would make more sense because its going to be lighter than the 10in wheel.
no makes alot of sense. thanks for the help guys. i appreciate it.
