275 vs 300 lb springs
  • 275 vs 300 lb springs
    The 275's just aren't working for me on the street, way to much header scraping and bottoming out.. Since most of you know I am inclined toward drag racing not cornering.. Will a 300 lb front spring help with the bottoming out and still maintain the drag qualities of the 275's? The 300's are listed as street/strip. A 325 would probably be too stiff?? Shocks are coming off when I get my car back, which spring should I go with???? I understand the higher spring rate will comprimise the drag qualities of the 275s, looking to meet somewhere in the middle...lol
    i would assume that should help a little bit larry
      I figure for the price it's worth a shot... I'll keep my 275's and if I don't like the 300's I'll sell em..
        exactly
          id try em, the 275's with a iron block in my car was scrapen the y pipe all day like i said in your other thread.
          i say go for it, i was gonna go stiffer on mine if i kept my car
          The LS1 or Go Home Crew
          ASE master certified
            SO do you think 300 or 325? 325 is actually recommended for the weight of my car, 3600 lbs..Well I think that's what it weighs..
              larry (1badair) will have a better answer for which ones since he knows alot more about them then i do he will prolly chime in soon
                I would probably go with 325's since your full weight and getting heavier.
                  great minds think alike...
                    i have the 325 pound spring on my full weight car, they work fine
                      Cool, thanks man!
                        QA1 has a disclaimer that 275lb springs are known to blow out shocks when going over pot holes lol better swap em out Larry.
                          LOL, They will be changed in the spring..
                            I have the 300# springs on my QA1's. Car weighs 3720 with me in it. I don't seem to have any problems driving them on the street however I have QTP headers which seem to tuck up a little tighter than most.
                              I'm just going with the 325 lb drag springs
