my damn Z06 Motorsports rims finally freakin came today!! took a few shots of one of the 17's and one of the 18's in my office...so here's a lil "glimpse"....but im sure just about everyone has seen these before...but now they're mine!!!! can i get a ????
the one on the left is the 18x10.5 the one on the right is the 17x9.5
still ****ed up...damn im about to have a freakin temper tantrum!!!
if i shrink it in paint..they get all messed up edges.....if i load 'em to Photobucket..they get retarded from there...and my camera takes blurry damn pictures even if i am holding still completly...and if that all goes well...the flash either is way too much...or now enough...it's a piece of shit....damn i need a better camera and it's not at the top of my "to buy" list
What kind of camera?
You might be dealing with non-camera related issues. Regarding the glare, see if your camera has "night scene" mode or option - it might reduce your flash glare.
For resizing, I don't use paint, but try a program that can shrink (resize) by an exact number of pixels, and reduce the size (always from the original) by an exact factor. For example, if the image is 2,096 pixels wide, reduce to a size of 1,048 or 524 or 262 pixel width. This will minimize your blurring from resizing (shrinking). Normally, your height will have similar factors to divide by, to keep the aspect ratio the same.
Even the best camera will produce blurry resized images if you're not careful. To test, try reducing like I said, and then reduce to pixel width 5 pixels off from that, and then look at the 2 results you saved, using a different image viewer - you should clearly see a difference in image clarity between the 2.
You had asked about tire sizes. You've mentioned what you had decided, but haven't said that you mounted them yet. So I don't know if this wil help.
Many details have not been mentioned here, so I'm not sure what your intent is. Are you planning to have them mounted and balanced with road force tension?
I have also become confused from info mentioned in this thread. Apparently stock Z06 tires are 265/40
