Front shock removal question.
    Originally posted by GETGONE View Post
    A little tip for future removal, swap the torx bolts on the drivers side with the regular bolts from the passenger side. You can take them out with a box wrench(ratcheting ones are great!) and not have to loosen and pull out the master cylinder again. I did this on both my cars when I had them apart. I bought a heavy duty spring compressor but the hooks are so large it's difficult to get it apart and back together without them being in the way. NAPA will charge about $30 to remove the springs for a pair.
    Good tip on the Torx bolts.. Thanks!!
      Originally posted by TSTONE View Post
      2002 Pontiac Firebird | Camaro, Firebird (VIN F) Service Manual | Suspension | Front Suspension | Repair Instructions | Document ID: 716134
      Shock Absorber Replacement
      Tools Required
      J 34013-B Strut Spring Compressor
      J 34013-114 Shock Compressor Adapter
      J 34013-88 Strut Compressor Adapter
      J 39549 Ball Joint and Tie Rod End Separator
      J 39642 Modular Shock Nut Removal Tool Set
      J 34013-115 Modular Shock Alignment Rod
      Removal Procedure
      Thank you!!!
        welcome
          what springs do you have?
          QA1's with 315 LB spring rate..
            Drivers side shock is out, spring removed, I just unscrewed the ride height nut until I could spin the spring by hand and dropped it out.. Took about an hour.. Tomorrow I'll do the pass side, going to be a pain because I have to park my car close to the garage wall on that side, only have about 2 feet to work between...
              PLENTY of room! I had less than that when I did both my SS and the V6 in my little 2 car garage with a vehicle on the other side. Just need to have it jacked up enough so you can crawl under it.
              Wade
                LOL, I'll take your word on that.. Glad I decided to have the shocks rebuilt, the drivers side is shot(sure the pass side is too).. I can compress and decompress the full travel of the shock with no resistance.. So I guess I have been riding my springs the last 2 years, explains the bottoming out problem I have...
                  YEAH! I thought something was messed up with your car when you launch that nose jumps up REALLY high for a street car. I couldn't find that bump at Stanton you were talking about. Nothing felt that bad to me at the end of the track. Guess we know why now!
                  Wade
                    I don't know if you saw it, but here's the vid where I bottomed out hard 3-4 times just after the trap.. Turn it up and you'll hear it.. Even though the steering wheel didn't move much I had a handfull, believe me....
                      Holy crap! How did you drive around like that for 2 years?!?! That's crazy bouncing! I couldn't stand driving my V6 around for 2 weeks while I waited for my replacement shock to arrive when one of the Tokico's blew out on me!
                      Wade
                        Well, believe me, I got to know every bump in town and SLOW down before I got to it..
                          if you need some help, wait, since you know how to do it now, i need to replace all of mine before spring, haha.
                            Yours will be different from mine.. I was able to skip some steps because I could release the tension on the spring while still mounted in the car and just slip the shock and spring out.. Pretty sure yours will have to come out as a whole unit, spring/shock together and then get a spring compressor to remove the spring.. We'll figure it out.. Let me know.. If you're bored tomorrow I have another side to do...
                              sounds good, what time?
                                How's noon sound?
