Originally posted by 1BADAIR
View Post
Poly motor mounts, anybody use em?
InActive Member
- August 29th, 2006
- 1456
- Josh C.
- 1997 Z28
- Fraser, MI
- Electro-Mechanical Engineer
Whats NVH?The Chevy Camaro was built with a single purpose in mind which it executes flawlessly...Going very very fast in a straight line until your hair catches on fire.
my motor mounts came apart easy, get a drill and drill out the one side of the clam shell and grind off the rivets on the otherside and pop em apart
i had a poly trans mount last year and no noticeable probs but i also had td's dumped lol.
its no caddy so i'm not worriedsigpic
The LS1 or Go Home Crew
ASE master certified
Poly mounts came with my turbo kit and I don't notice any difference in vibrations. Then again the car has a stiff suspension so any bump in the road is transmitted.
I also have a poly trans mount that I installed previously when my factory rubber one was torn. The shifter was moving a lot when loading/unloading the engine. My shifter physically moved up and down a lot. It was unnerving. Hardly any motion after the install. It is nice. But i did not install that extra plate the trans mount came with. That was the suggestion I saw over on LS1tech. Works well for me.
Yeah that was fun. I used every elbow and extension or wrench I had to get those out. It was fun....Originally posted by Superman09 View Posti just put poly mounts in..... what a treat
I wouldnt look forward to the install if i were you, haha. Annoying little bastards!
While getting the drivers side bolt in, I slipped with the prybar and seriously clocked myself in the side of the head. My jaw was sore for two days. My g/f at the time joked that she was telling people she hit me.Originally posted by Superman09 View Postwell removing the old mounts from the brackets was a PITA. The worst part was trying to get my motor mount bolts in though..... the poly mounts are a b***h to line up with the motor mounts, i struggled with pry bars, hammers, screw drivers, and wrenches for a few hours, lol.
Same here.Originally posted by Syn View Postmy motor mounts came apart easy, get a drill and drill out the one side of the clam shell and grind off the rivets on the otherside and pop em apart
its no caddy so i'm not worriedLast edited by Hugger Z; February 21st, 2008, 03:46 PM.My Toys: Hugger Orange 1999 Z28 6-Spd Twin Turbo
1937 Chevy Extended Cab Pick-up (One of a kind)
Future Toy: Orange Ultima GTR or SLC
InActive Member
- August 29th, 2006
- 1456
- Josh C.
- 1997 Z28
- Fraser, MI
Well, I got the trans mount today, the motor mounts will be in tomorrow. I kinda chuckled when the guy asked me what color I wanted ( black or red). I was like "color? Its an F'n motor mount". So i opted for red, red wasnt in stock, so I got black...then I found out you can get them chromed too, I dont know why.
I think Im going to ask them not to use the pre-load plate as well. Hope they know what Im talking aboutThe Chevy Camaro was built with a single purpose in mind which it executes flawlessly...Going very very fast in a straight line until your hair catches on fire.
Be patient. Getting to those bolts is tricky. Hopefully getting it all back together will be easy for you if you are not changing the k-member too. I did my k-member when I did my motor mounts with the turbo kit and that was a royal PIA. Just take your time, have some extra hands there for assistance and make sure you have plenty of ratchet extension, elbows, etc to get at the bolts. I contorted myself in so many different ways I think I gained some flexibility during that install.Originally posted by MORNINGSTAR2101 View Posti will be tackling this myself pretty soon. any forewarnings or tips?
haha, thanks. im hoping my tiny-ness will prove to be a huge advantage here tooOriginally posted by Hugger Z View PostBe patient. Getting to those bolts is tricky. Hopefully getting it all back together will be easy for you if you are not changing the k-member too. I did my k-member when I did my motor mounts with the turbo kit and that was a royal PIA. Just take your time, have some extra hands there for assistance and make sure you have plenty of ratchet extension, elbows, etc to get at the bolts. I contorted myself in so many different ways I think I gained some flexibility during that install.
