Planning on buying either 15x11 or 16x11 rims for the rear. Who is running this size rim and what backspace did you use? Any problems squeezing the 315s in the wheel well. Will the tire stick out some or does it sit in the wheel well with the correct backspacing? I want to maximize my nitrous setup when at the track, and my 18's just aren't going to cut it.. Thanks!!
Do these offsets sound right?
Rim width offset tire sizes
10.5" ... +38 to +50 mm .... 285, 295, 305, 315
11.0" ... +45 to +56 mm .... 305, 315, 335
