I've seen a tutorial posted about replacing rear drums w/ disc. Didn't look too scary, but since I'll be replacing my 2-piece driveshaft with a 1-piece, I have to wonder if swapping in a different rear-end that already had disc brakes would be simpler than retrofitting the existing axle with discs. Watcha think?
Rear disc brake upgrade?
well that would proably be the easiest... all you really have to do then is bolt the axle in and bleed the brake lines... i want to do that if i ever come across it... not that it really matters you do very little breaking in the rear and unless its a aftermarket upgrade bigger cali. and rotors it doesnt make a huge difference over stock from what ive read.. might get you and extra couple of feet 60-0 but sometimes that makes the difference in 3 grand in body work...lol but disk is much easier to maintaine... and apperance wise through the rims... looks way better...Originally posted by Frank The TankTook the restrictor plate off to give the Red Dragon a little more juice. But it's not exactly street legal, so keep it on the down low.
the master cylinder is different? i have disk on my 84 parts car just its rusted out to bad to use... and it has the same master cylinder...hmm the proportioning valve im sure is different i didnt even think of that...Originally posted by Frank The TankTook the restrictor plate off to give the Red Dragon a little more juice. But it's not exactly street legal, so keep it on the down low.
drum/disc swap
I just checked at the www.camarov6.com site, and the consensus seems to be that the part numbers for the master cylinder, proportioning valve, and brake lines are all the same; No need to change.Originally posted by 1bad83talol shawn, you have to replace the proportioning valve and the master cylinder also. You can't just swap the rear ends.
Silly people.
InActive Member
- February 27th, 2006
- 962
- Drew
- Drifter.
- Grosse Pointe Woods
- Professional Racer/Builder/Tinter
From personal experience, the master cyl and prop valve do not need to change.
SpeedDetroit Speedshop <Owner> Detroit's Only True Grassroots Speedshop
http://gasfed.blogspot.com/
Originally posted by KuruptWS6spdAnd yes my box is ALWAYS this clean
The master Cyl should interchange, but the proportioning valve needs to change. Disc brakes require a 10psi residual valve where as drums are 2psi. You need a disc/disc valve so that way both front and back will have 10psi check valves in them. This keeps a constant bit of pressure in the line so the pads ride closer to the rotor.
Alternitavely you can buy little inline valves from companies like Willwood.
ANd oh yeah I might have the number switched, it might be 2 disk 10 drum its really too early for me to remember
