How to flycut pistons in an LS1 for free! (almost)
  • How to flycut pistons in an LS1 for free! (almost)
    While degreeing the cam in my new LS1 build, we found that my piston to valve clearance was only .055 on the intake side, so they needed to be flycut. Unfortunately, the cheapest tools I could find we're over $100 and that was just for a single cutter and mandrel. Add one for the exhaust and you're looking at $200. The only other option is to rent a tool to do the job and that too costs about $200 to use. That wasn't in my budget, so I started brainstorming and came up with an idea that works perfectly and costs barely anything. It was free for me because I already had the materials needed, but if you have to pay over $5 to do this, you're doing something wrong.
    Items needed:
    1) Adhesive backed sandpaper, I used 40 grit
    2) Stripped cylinder head - I used an old one I had lying around because my ported heads have stock size valves. If you have larger valves or do not have an extra head, USE ONE OF THE HEADS YOU ARE PUTTING ON YOUR CAR! This method of flycutting will absolutely NOT damage your cylinder head in any way unless you really screw something up.
    3) Either an air drill or a cordless drill with a lot of power. We used a Milwaukee 28V cordless.
    4) Masking Tape - Tape across the entire deck on both sides to keep grit from contaminating your engine. If you do this correctly, there will be no path for anything to get inside.
    5) Some sort of tool that can be inserted between the chuck and the top of the valve seal to give repeatable depth results. We used a small flat wrench that measured .080 thick and it worked great. You could even make one out of a thin piece of bar stock.
    6) Shop Vac - to suck up all the aluminum and grit that's produced during cutting.
    7) Some sort of cutting tool to make small sanding discs slightly larger than your valve. We used a 2" I.D. exhaust pipe with the outer edge chamfered to make it sharp for cutting. If you have larger valves, you could chamfer the inside edge until you get a suitable diameter, or you can use any sort of round tube that you can just barely fit around your valve. Having a slightly larger diameter disc causes the paper to cut slightly larger at first, then closer to the actual valve size as pressure is applied. This bevels the top edge of the cut to eliminate hot spots in your combustion chamber.
    Now that you have everything needed, let's get started. First you will have to cut out your sanding discs. We used a press with the aforementioned piece of exhaust tubing which gave us accurate, repeatable results. If you don't have a press, lay your sandpaper on a block of wood grit side down and use a hammer to strike the tubing to "cookie cutter" out a disc. If you have a pipe end that you could slide over the end of the exhaust tubing, that would be VERY helpful here. Cut out 8 discs for the intake side, then switch to your exhaust cutting pipe and cut out 8 more ( this is optional, as I only needed clearancing on the intake side ) . You should be left with something that looks like this:
    Now clean off the deck of your block with whatever you choose, but make a final pass with lacquer thinner or electronics cleaner so your masking tape will stick. Tape off the ENTIRE deck so there are no paths for grit to get into. However, you will need to punch a small hole in the center of each cylinder to allow air to escape or be drawn in. If you tape it off well enough, a piston can produce so much suction that it will rip your fresh masking job. Not good. Here's the final product (note the small hole in the center):
    When that's done, you're ready to start flycutting. You should have already determined what your piston to valve clearance is, and in turn you should know approximately how deep you need to cut to get proper clearance. We went for about .120 clearance ( from .055 measured ), so we needed .065. We found a small wrench that measured .080 thick and used that, figuring the paper itself was about .010 and we wanted to err on the larger side as to not make multiple cuts on the same valve. Place an adhesive disc on the face of your valve as show below:
    Once that is done, turn your engine over until it is at TDC (doesn't matter which pistons you start with, two will come to TDC at the same time) and then back it off slightly (LS1 pistons come out of the bore, so if you go to true TDC, your head will not seat properly). Once this is done, determine what chamber your valve needs to be in to make the cut on the first bank of cylinders and insert the valve into the valve guide (a drop or two of oil should be placed on the stem). Pic below:
    After inserting your valve, place the head on the block and lightly bolt it down. We used 3 bolts in a triangle shape, as it made for quick installation and removal. Two in the dowel holes and one in the center between cylinders. You don't need a lot of pressure to make these cuts, so there is no need to clamp the head down hard. Once the head is bolted down, turn the engine over so the piston butts up against the head. DON'T FORCE IT! All you need is for it to touch the piston. Then take your finger and push the valve stem down until it touches the piston:
    Once this is done, place your depth tool (wrench or whatever you've located) on the valve stem:
    Then take your drill and put it over the valve stem while tightening the chuck - the object is for the fingers of the chuck to be resting snug against your depth tool. This will NOT damage your valve if done correctly, my valve looked perfect when done:
    Remove the tool and visually verify that the proper clearance exists between the valve seal and the drill chuck. You can do this without a seal installed, but your chuck may not seat far enough down on the valve:
    Pull the valve up slightly off the piston and start the drill. Push downward using steady pressure and watch the gap between the drill chuck and the valve seal decrease until the chuck contacts the seal. At this point, your cut has been made.
    Remove your drill and your cylinder head, then use a measuring tool to verify your cut is as deep as needed. Use the vacuum to suck up all the debris from the cut you made and in the combustion chamber/ports, then attach a new sanding disc to the valve and insert it in the corresponding chamber for whatever piston is at TDC on the other bank of cylinders. Once you've made those two cuts, tape over the cuts with a piece of tape and rotate your engine so the next pair of pistons hits TDC and repeat the process. When you're done, again go over the engine with the vacuum and then remove the tape. You should be left with nearly perfect flycuts and a lot more money left in your wallet! ( As a side note, if you DO use a head that you are planning to bolt on your car, clean it thoroughly with soap and water and an air gun after doing this process or you will get a lot of debris in your engine. )
    Awesome writeup and AWESOME idea - thanks for sharing!
      That's a nice writeup, thanks for the info!
      Originally Posted by 1BADAIR
        cool idea - just but keep in mind you lose compression when doing this
          The valve reliefs are .4 CC each. That wouldn't cause you to lose more than maybe .05 from your compression ratio. My pistons are all .007 out of the hole compared to the stock spec of .006, so I'm pretty sure I'm good, lol.
            Very trick!
              great writeup! you deserve a round of applause!
                Very good write up, thanks!!
                West Michigan Pontiac Club
                  Did the pistons have the valve relief before you started or is that 100% your work?
                    There's a good question. By the way, this could probably be a sticky, should we have them in here.
                      LS1 Pistons are totally flat with no valve reliefs at all. So there's no room for error with a bigger cam. Good thing we checked too, this is only a 228 @ .050 cam and it was too close!
                        Wow. That is incredible, Patrick - it looks so simple!
                        Very nice work!!!
                          Nice work. Good write up!
                          Aren't most valve reliefs cut to a larger diameter than the face of the valve though?
                            Yes, they are - that is why the cutting discs we used were about 1/16" larger diameter than the valve, so they'd cut a larger eyebrow out of the piston. We measured and double checked it, they're good to go.
                              Now thats using your skull for more than a brain bucket..............
                              Nice write up my friend!
