[MENTION=2062]TORN[/MENTION] who did you have do your conversion?
Project First iroc
Obsessed- June 6th, 2012
- 505
- Brian
- 1991 Camaro RS/1991 Camaro Z28
- Wixom Michigan
- Truck Driver
Thanks Brian. I will post some more progress pics. I'm bad at keeping up on threads. Lol. Plan is to just drive it. With the 305 TPI, t56 and the 4:10 gears. I am also doing all of the suspension. Probably going to use it as a daily driver/ shop car.
- 505
- Brian
- Wixom Michigan
- Truck Driver
Sweet! Is the blue car running again yet?Originally posted by Curt_irocz View PostThanks Brian. I will post some more progress pics. I'm bad at keeping up on threads. Lol. Plan is to just drive it. With the 305 TPI, t56 and the 4:10 gears. I am also doing all of the suspension. Probably going to use it as a daily driver/ shop car.sigpic
No, the engine needs to be assembled and put in the car, along with wiring, fuel system and all. Not to sure when I will finish it. Hoping by June.
- 505
- Brian
- Wixom Michigan
- Truck Driver
Well I hope you get it together sooner than that. How much faster will it be than the previous setup?sigpic
I heard some bad news about this car... Maybe Curt will chime in
[MENTION=2246]Curt_irocz[/MENTION]sigpic
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
the bump and leave news?91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
ok, sorry guys.
pulled the rear end
Took it next door to Henn Racing for a 4;10 gear install
Cleaned up, and Back together, I also bent up some new brake lines.
Hawks crossmember dos NOT fit, doesn't fit in the rails, and if It did it wouldn't clean the factory fuel and brake lines
oppps
better
t56 in
also Had these parts I from my 1995 sitting around, so I put them in.
