$800 Cavalier
  • General Altimax Arctics.
    Couldn't beat the deal Tire Rack was running - $50 Rebate (from General) on a set of four General tires, and then another $50 rebate (From Tire Rack) on a set of four winter tires - and then you also get a $50 certificate towards four non-winter tires of the same brand in the spring. The all-seasons on the Cavalier will likely need to be replaced next year, so this works out perfectly.
    The General tires are under $70 a tire, and they're a previous-gen Nokian Hakkapeliitta tread pattern, which would explain just why they such monsters in the snow.
    I was also considering the Michelin Xi3s that we have on the Cruze (which are fantastic), as those are LRR tires (without being awful), have great dry/wet characteristics, handle snow great, wear very well (and have a treadwear warranty - on winter tires) and actually handle better than the stock FuelMaxes.
    They had a larger manufacturer rebate ($70 vs $50, plus the $50 TR rebate), and would only be about $20 more for the set - but the all-seasons were almost double the price of the Generals, and the better out of the two available wasn't that much better than the already excellent RT43 all-seasons (in the tire size, it was #1 and the Generals #4 - out of like 30 tires, pretty close). And actually, though the Xi3 is a little better in dry/wet, as well as ride/noise/treadwear, the Arctic is better in light and deep snow.
    I'd certainly recommend the Xi3 (they get us up our driveway with more snow than the car has ground clearance, with no issue), so I can imagine the Arctics will be just as great.
    All in all, the full set of these Arctics cost $323, and thus will be $223 after the rebates. At least I still own something with small tires, love how cheap they are!
    • Thanks Kyle, appreciate the detailed response! Who mounts and balances them for you?
      Makin Torque.
      • [MENTION=709]bri2203[/MENTION] does them for me.
        • Brian mounted/balanced the tires for me on a set of steelies I bought, on Saturday.
          Yesterday I Plasti Dipped the steelies white, to further confuse my neighbors. White for winter, or something like that.
          • I like the look - what does that cost?
            • Originally posted by TSTONE View Post
              Plasti Dip is about $6 a can at Home Depot or Lowes (more colors available on Amazon). And its more of a rubberized coating, so it reacts well to impacts (from, say, stones or salt) and temperature changes. For five relatively heavy coats, I used a can and a half.
              I did black Plasti Dip on the Cobalt's steelies, and even through two or three winters, they still look the same. Works really well for painting front grills, as well. Plasti-Dipped the chrome grill on my brother's '01 Century black, and it's held up real well. Plus, if you don't like it, or want to change (assuming you painted it right), it peels right off.
              • I dipped my old Liberty's wheels anthricite and they held up over a winter very well (sold it after that 1st winter)...I didn't baby that vehicle; I used to plow into snowbanks and stuff.
                • Ive got about 2 years on my plasti dipped wheels and theyre just starting to peel. Going to redo them soon or this spring.
                  • The only ***** I had was everyone said "just spray it and it peels right off the tires!"
                    My ass it does. I got massive blisters on my fingers from trying to rub the overspray off the tires.
                    • Originally posted by Atrus View Post
                      Oh, yeah, that's not right - it basically adheres directly to it.
                      I use a trick I learned, which is to put index cards all the way around the wheel - between the wheel lip and the tire - provides a sort of "cone of shame" for the wheel, and keeps nearly all of the extra paint from getting on the tire. I have some minor (as in, you need to know it's there to see it) overspray on the tires, but that's it. Also, that requires no taping - just set them in, and pull them out when you're all done spraying. Super easy - and reusable (if you want).
                      • Wow that sounds sooooo much easier than taping i spent hours on taping mine off last time. More work than the painting itself.
                          Yup! I mean, I taped the back side at the lug holes, hub hole and the holes in the main face of the steel wheel - but that was mainly just so I didn't have paint go onto my garage floor.
                          Setting up the index cards takes all of five minutes for all four wheels. Suuuuuper quick, easy and effective.
                          • Well for the garage floor you could just set them on newspaper
                            • ...yes...I sure could have...
                              Not sure why that slipped my mind - I have two brown bags full of them in the garage.
                              • The cards do work awesome. I put them behind my fender flares when I dipped the lower part of the body. I was told it peels right off the tire, so I figured I'd save myself the time. I was very very wrong
