Project "Because Streetcar"
  • #61
    Day 1 progress
    Why cut a 8pt rollcage down to a 6pt roll cage? "Because Streetcar"
    I may end up going back to a full cage, but the halo was not how I would put it in. Also, Ive never messed with chromoly before, holy shit is that light. awesome!
    So today I cut the cage down and started cutting a few more brackets out that I wont be using... Some of the metal work is a little to "race car" so Im going to clean it up a bit, while cutting weight. Most of the day I spent running in circles... This is a big project to jump into the middle of... So much that I want to do...
    • #62
      that wasnt a 6 or 8. a track wouldnt have let it run at all without door bars
      • #63
        Clearly...
        They had all ready been cutout, along with the passenger front down bar. Thanks for the super helpful reply, I had a big trip planned to go to the track tomorrow, but looks like I can save myself some time...
        • #64
          Thanks guys.
          Calling it a night... 5:30AM (Got a little carried away) (Still Day 1)
          Disassembly is complete..
          Next: Ill work on figuring out measurements for my FAB9 and get the windshield out and start cutting out the cowl/firewall/trans tunnel/strut towers/etc... and see where I stop... Should be fun.. Im going to do my best to remove all unnecessary metal, either by cutting out entire brackets, or hole saw where optional..
          I plan to gusset the cage to the chassis, so that should bring some strength back to it.
          • #65
            Well I decided I didn't like the tubs that are in the car, so I just bought new 40" tubs.
            The tubs that are in it are really only mini-tubs... so I am going to do a full tub... droping a lot more weight in the process... I am going to bring the tubs up ~6 inches, so I can fit a big tire without having the car in 4x4 mode...
            • #66
              Got a tire off a top fuel dragster for mockup, while I wait for my wheels and tires.
              uninflated it is roughly the same size as my tires inflated, so it works out well.
              These pictures are taken at full compression.
              • #67
                Don't know why, that made me chuckle a little but. Maybe its sheer awesomeness?
                This is one of the most ambitions projects I have seen in a while, definitely subscribing. You have this on tech also?
                • #68
                  Thank you very much,
                  Yea, I have this build everywhere. lol
                  • #69
                    I have some Mickeys for a 10.5 car for a 16x16 rim if you want to mock that size
                    • #70
                      Do you have someone doing the turbo kit? If not and are looking or interested, let me know!
                      • #71
                        Hey Ryan, what size are they, if they're pretty tall, I would really appreciate borrowing them
                        Text/call me 810-569-5201
                        Im going to be fabbing the turbo kit myself, thanks for the offer though.
                        • #72
                          Ryan, thanks a lot for letting me borrow that tire.
                          • #73
                            Thought the same....kind of "cartoonish"' lol. Used to sketch cars with tires like that....
                            Looks good Trev.....
                            • #74
                              No problem at all. It was nice meeting you guys. That car will be burning off it's own set soon enough.
                              • #75
                                that looks fricken awesome!
