Project Panther
  • Just received an email back. They do not make a 2.5" . Made a prototype, but lacked the customer support.
    Any one have an idea on the xpipes I posted?
    Sent from my C811 4G using Tapatalk
    • What's wrong with a 3" setup? Room to grow.
      2002 Z28 Camaro A4
      • Don't want 3". Camaro will be fine with 2.5". Will be plenty for the power I want to make.
        • Agreed but if there is 3" readily available, for a good price.
          2002 Z28 Camaro A4
          • I had LPP duals on my camaro. Looked very similar to the ones Jeremy posted except they had mufflers.
            • You may want to reconsider the Phab setup. I have a "full" 3" exhaust and not full 3". It goes down to 2.8 ish at one point.
              Everything fit to gather great and outside of my header problems looks to be exactly what I wanted, and your not going to find a better price.
              I wanted their TD system but didn't want to deal with the noise/drone.
              • Meh IDK, I might want to eventually go lower and could save some money doing 2.5" now. Good price yes, bit still weighing my options for 2.5.
                Going to chat with a couple of my commercial accounts and show pictures to get a price on a system.
                Mean time, still going to research the xpipe
                • Pypes XVF10
                  Summit Universal
                  Pypes XVA10
                  Flowtech
                  I guess these are my choices. I am thinking the Pypes tunnel (1st pic) would be better starting point? Or would the summit be.
                  So just need to figure out the X pipe,buy 1 bullet,turn downs,hangers,clamps ...
                  • Originally posted by Nocooler View Post
                    Have you looked at the phab setups on ebay?
                    They have one without mufflers - seems reasonable to me. http://www.ebay.com/itm/1998-2002-Ca...a0954a&vxp=mtr
                    Just another option. I think Mike @concept had their setup on his pumpkin.
                    I wish I could run dumped duals - but I don't have room with the 3.5" driveshaft and tunnel mount torque arm.
                    What cross member are you running from mwc?
                    I bought 2 cross members from him one for this season while the set up remains a n20 combo and another one that will tie onto the sfcs when she gets a snail or 2 next season.
                    Just curious cause he said he has guys running the 3 and 3.5
                    X pipes and not having issues
                    • Originally posted by dawdaw View Post
                      I have the cat-back x-member, the double drop would help but then I have the big ass 3.5" aluminum PST drive shaft that makes it tight to say the least. The true dual crossmember is a joke - my car would never hook with it as high as it mounts the torque arm.
                      Rolo - I'd just go 3". No need to go 2.5" unless you need the extra ground clearance,
                      2000 Formula
                      fixed slow junk
                      • I want the clearance because I plan on going low. And dint want to alter the exhaust if I can avoid it right now
                        Something came to mine after digging on ls1tech for mandrel bent. Why not just individually buy the bends and straight pipe? Alot of posts on ls1tech, user stated that they had to cut and weld the pieces from the universal to fit many times(obviously) so why not just buy some of the bends and what not to piece together a custom "custom" kit?
                        Im having a hard time finding all the degree bends but here is what I gathered so far (hoping that its right). These degree bends I believe should follow the Y pipe configuration until you hit the X (little cutting and welding needed)
                        8ft of 2.5" straight pipe $27.94
                        (2) 90* bends $39.94
                        (2) 45* bend $35.94
                        (1) X $35.06
                        I feel in this small list, I am missing another bend or two? Maybe a 120*?
                        • never went thru this thread till now. Nice car you have rolo and very nice mods!!
                          Originally posted by BP_Z28 View Post
                          Would rather have an over axle out the back style using the magnaflow, but I have other issues I need to address.. aka starter,battery
                          What brand of mufflers are these?
                          • Magnaflow 14419.
                            I have the magnamouth on my camaro right now.
                            The bullets can tuck up perfect right before the tips if going over axle.
                            You can hear the bullet here..dont mind the exhaust leak . Opened the cutouts around .40 mark
                            You can hear a track pass with the exhaust here
                            • sounds good rolo!
                              • Well figure I would update right now, to a post I should have done mid summer or so. Cat has been out the bag with a couple members on here, so why not just let it out. Had to dig around for the picture but finally found them last night.
                                Jacked up and ready to go
                                Time for the disassemble
                                Out with the old
                                In with the new
                                Updating this post from a previous topic since all my pics were deleted by my mistake
                                So on to the gauge installation.
                                Started when Michael made a visit to Lapeer for me to test fit the hard tops pillar
                                The goods
                                Decided where we will weld the bung at
                                Fuel pressure sender
                                Putting it all back together now (you can see where in pan the bung is welded)
                                Trans was being a PITA to remove.
                                Met Jeff and bought his cooler
                                Everything was done early early spring. Ken was a very big help, and learned alot.
                                And the video.Had to get a feel for the loosey goosey..My neighbor *****es about how loud the camaro is all the time (so I'm told from a friend)..and I always ***** about the damn dogs always barking so it is what it is so I edited her out
                                https://www.youtube.com/watch?v=XXiF...ature=youtu.be
