Finally (seems like this is not my first time with this title) Its running again
  • [Project] Finally (seems like this is not my first time with this title) Its running again
    Was cruising last year down 16 mile road and lost traction due to coolant coming out the vent in the resi. (im running full slicks) Driver headgasket was blown. cylinder 1 and 7 in the bottom corners. cleaned her up as no damage was done other than the gaskets and some dirty plugs. replaced the plugs. went ngk Race .460 heat index 6 instead of the tr6s i had in it. changed to a TCI Rattler harmonic balancer. and swapped to a new 7qt oil pan. put it all back together turned primary fuel pump on and Fuel everywhere all over the carb. Just rebuilt it today and tossed it back on and she fired right up heres a video of it running.
    04 dodge ram HemiGtx 001/433
    08 yamaha R6 (fuel saver)
    that thing sounds mean! congrats on getting it going
      sick man, sounds great! good work John.
        I'll take a piece, good to hear its running again John
          Thanks guys. With my back it was a bit of a task and I had to put it off and put it off throttle response seems perfect gotta try to road test it and get her out to woodward. And jeff anytime man I've been waiting for us to line up again. My bottles disconnected and wont be reconnected til next year more than likely. Motor to motor
            Sounds like a good time, put a few miles on it and let me know when. I was hoping Motown was going to have a rental at Milan this year but the interest seems low again.
              I may have some shake downs with it at lapeer. no full throttle after i firewall the trunk and fiberglass the openings in the wheel wells because i only tacked the tubs in. im down to line up for sure with you. Infact i wont even make you post up a buy in for it. Just got to get my hands on a trailer. Are you heading out to woodward?
                I'm planning on heading to Woodward saturday for sure at least for a few hours.
                  Are you going to the Sq Lake spot? ill be at 14 mile and WW aside from cruising a little
