Good to know! I was planning on using a bolt then my buddy suggested a rivet. So yeah even better.
1999 Z28 Camaro (winter to do list)
LCAs and brackets should be torqued with all 4 wheels on level ground, make sure you do this correctly otherwise the suspension will be noisy until it settles properly and that could possibly loosen the bolts anyways.Doing less with more
It can destroy the bushings as well.Originally posted by DETROITMUSCLE View PostLCAs and brackets should be torqued with all 4 wheels on level ground, make sure you do this correctly otherwise the suspension will be noisy until it settles properly and that could possibly loosen the bolts anyways.
Originally posted by DETROITMUSCLE View PostLCAs and brackets should be torqued with all 4 wheels on level ground, make sure you do this correctly otherwise the suspension will be noisy until it settles properly and that could possibly loosen the bolts anyways.Well FML, I actually remember reading that on the how to site. Grrr guess I have to put it on the list to do.... Thanks!Originally posted by bri2203 View PostIt can destroy the bushings as well.2002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
I would have to agree, previous owner kept good care of them!Originally posted by kyleozzie View Postman those are some good looking lca's
haha
2002 Z28 Camaro A4
Thank you! ..... To be continued........................Originally posted by sman View PostLooks Good!
Now wheres that headlight write up?!2002 Z28 Camaro A4
haha i'm pretty sure ken bought those from a friend, who bought them brand new. should be perfect!98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
Picked up the other 2 tires...... Falkens
Got all 4 wheels and tires mounted and balanced.
Also sent the PCM out to Frost to get tuned. I plan on bringing her out end of next week/ beginning of following week.
I need some lugnuts. 20 to be exact. Black would be great but I am guessing my chances are slim to none. NOT STOCKERS2002 Z28 Camaro A4
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- 1999 BBM z28 Camaro
- Saginaw Michigan
- New Car Sales Consultant
Go to autozone they have black ones for $20-$25...they are locking too...i was looking at them the other day...if they dont have them in stock im sure they can get them.Originally posted by mcalus View PostI need some lugnuts. 20 to be exact. Black would be great but I am guessing my chances are slim to none. NOT STOCKERS1999 z28 Bright Blue Metallic 1 of 10
Thanks! I stopped by one and they only had chromeOriginally posted by Purple94Z28 View PostGo to autozone they have black ones for $20-$25...they are locking too...i was looking at them the other day...if they dont have them in stock im sure they can get them.
ill have to check out another Autozone.
I got an email that my PCM is on its way back from Frost already!!! I was planning on bringing it out at the end of this week but the 7 day forecast isn't looking so hot...(no pun intended)2002 Z28 Camaro A4
