Remember when you were going to use a FAST 102?
01SS - Restored Project underway!
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
Good deal, It will look much nicer shortened up!Originally posted by OVRKILL View PostHey Bryan, better late than never! Home sick today, I cruised through the first 15-20pages and lol'd seeing posts of my intent to make Power Tour in June......OF 2010!!!!
Thanks Jonny....yep, the system is looooong. Already shortened and 1" or so by cutting the header flange. Gonna cut another 1" off between the tips and mufflers to tuck and align better.
Originally posted by Lucky SOB View PostRemember when you were going to use a FAST 102?
Would be fun to pull some of the delusional quotes over the past couple years....there are some beauties in here.
What little I knew.......Originally posted by OVRKILL View PostTHAT 460 is an all the boxes checked, crazy expensive billet internals, sheet metal intake, etc. Same block and displacement, just the run of the mill, "budget" version, lol. Lunati, JE and Callies stuff...PI LS7 heads, 102 FAST intake, NW 102 Tbody, etc. Cam is undefined at the minute.
......oh yeah, like I would ever consider a sheet metal intake
Makes the "over budget" license plate all the more relevant. Three intakes, four cams, two sets of heads later....yep, pretty "run of the mill"
Not a good start to the next phase. Started filling fluids in prep for shipping to the shop. First fluid....radiator. Apparently nicked it on Saturday during the install of "other" things
What's wrong with this picture?
Finally closing in on completing ther AC plumbing....PITA!!!!
Smooth a few welds like so...
Dremel, sandpaper, air tools, elbow grease and taaaadaaahhh.....shiny stuff
Just need to fit for lines, final polish and I stall.
- Greenville, MI
- Die Maker
Care to inform me on the grit steps you use? I see you use Mother's Increadible Billet Metal Polish
NOW you're just discovering thisOriginally posted by nascarnate326 View Postyou sir are crazy
Originally posted by hoogiesngrinderz View PostCare to inform me on the grit steps you use? I see you use Mother's Increadible Billet Metal Polish
For the most part, the OEM piping is pretty smooth. Crimp marks, deep scratches, etc, I started with 120 and climbed in increments of 1-200-ish.....120, 220, 400, 600 then 800 on the really visible stuff. Welds started with 120 rolls and a 320ish roll by Dremel then went by hand until it was time for the air tools.
Used Mothers to brighten things up for the photo shoot
....but in all reality will hit'm again with white rouge and air, Mothers for final touch.
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
TEASEOriginally posted by OVRKILL View PostSomething made noise today......
More info in a couple weeks...
