Who's teeing up Winter projects?
  • #91
    I hadn't planned to do anything to mine for the next few years, but I'm toying around with some ideas.. we'll see.
    -Derek-
    • #92
      new heads, new rear end, and may put the 382 back together
      • #93
        Bad ass bird Larry!
        • #94
          awesome!!!
          • #95
            I've got the center section out of mine right now. 4.10's, new bearings, seals going in it. Chassis Saver-ing the entire underneath, engine bay clean up, LS1 air box, new brakes, new shifter, install dash pad.
            2015 Silverado
            • #96
              Originally posted by Gaspo View Post
              what's the "somethin somethin"???
              LQ4 swap with an MPT76.
              • #97
                come out of another member's car? If so that car runs very well.
                • #98
                  Negative, building it myself. Truck manifold setup. Might go bigger (T88) Master Power is supposed to be bringing one out at the PRI show
                  • #99
                    nice! i cant wait to see that.
                    • X2 sweet build
                      • Originally posted by ThreeHonks View Post
                        not a whole lot of plans for my car, just some suspension work and minor changes.
                        Might try to get the 01 back over to the east side of the state so I can start fab work on it
                        sounds like u need help from a guy with a truck and trailer.. lol
                        what are u doing to yer car now james>
                        • Nate didnt you put a new clutch in your car over this summer?
                            Yes I did. I had my lightweight flywheel turned so it was nice and perfect only to find it it was worse than before. Now I am tearing it back out and putting brand new stock parts in. It didnt fit my style and my reason for having the car anyways. Hoping to use the clutch still as it has 1900 miles on it. If not, lesson learned. Since Ill have the T56 out, I figured it would be a good time to throw some longtubes on the car. Hopefully it makes the install a little easier, we will find out. Since I got eBay headers, I think its going to suck no matter what. I do know that next year, my car will sound better, drive better, and be faster than it was last year. We are going to WW too now that I trust my Vats system.
                            • turning it probably took that 12 pounder down to an 11 or 10 judging by the ammount of material the guy took off...
                                lol the lil LS1 isnt even out of it yet. I gotta get that thing out before I can make way for bigger plans
