Originally posted by scholtmj
View Post
STS turbo 3rd gen TA
What did you have done to your 305 to make it run a 12.0?sigpic
Spent a lot of money!Originally posted by Darrenscamaro View PostWhat did you have done to your 305 to make it run a 12.0?
Engine:
Stock GM 305 TPI + .030 = 310 Cubic Inches
TRW Forged Flat Top Pistons
Eagle 4340 H-Beam Rods
COMP Cams Xtreme Fuel Injected Camshaft: 268/ 276, Lift .570/ .565
Comp Cams hi energy pushrods
GM LS7 lifers
Comp Cams 1.6:1 Pro Magnum Roller Rockers
Comp Cams double valve springs
Comp Cams Double Roller timing chain
World S/R Torquer 305 Cylinder Heads 1.94/1.50 valves
Edlebrock Aluminum intake manifold
Accel SuperRam Intake Plenum
Melling high volume oil pump
Accel 26lb fuel injectors - NOT BIG ENOUGH
BBK 58mm throttle body
BBK Fuel Pressure Regulator
Summit electric water pump/Weiand Polished Aluminum Mech. pump
Procharger P1SC with Intercooler 6, 8, 10lb boost pulleys
Ignition:
MSD 6AL/Hypertech Coil
Taylor Spark plug wires
Accel HEI control module
Transmission:
Coan Engineering Street/Strip 700R4
Neal Chance custom 9.5 in lock up converter
Spohn Trans. Cross-member with driveshaft loop
Exhaust:
Ceramic Coated Hooker Long Tube headers
Custom H-pipe with Flowmaster mufflers
Rear End:
GM 7.5 inch 10-bolt housing
Moser C-Clip Eliminators
Moser custom alloy axles
LPW Ultimate 7.5 rear end cover
Strange Engineering 3.73 Pro Gears
Auburn Pro Limited Slip Differential
Suspension:
Front:
PA Racing Tubular K-Member
Spohn tubular A-arms with rod ends
Spohn pro-tour coil over kit 300lb springs
Koni “red” adjustable struts
Flaming River Pinto manual steering rack
Rear:
BMR Torque Arm
BMR Lower Control Arms
BMR Adjustable Panhard Rod
BMR Panhard Rod relocation Kit
Spohn QA1 coil over kit
Chassis:
Spohn Wonder Bar
Chris Alston Subframe connectors
Brakes:
Front: Power slot rotors
SSBC Electric Vacuum Pump
SSBC Force 10 Aluminum calipers
Stainless braided brake lines
Hawks Ceramic brake pads
Rear: Stock drums
Wheels & Tires:
Front:
17 x 8 Torque Thrust II Classics
245/45-17 BFG G-Force T/A KD
Rear:
17 x 9.5 Torque Thrust II Classics
275/40-17 BFG G-Force T/A KD
Drag Wheels/Tires:
17 x 11 Torque Thrust II Classics
315/35-17 BFG Drag Radials
Other:
Canton Racing coolant expansion tank
Dell Laptop with Bullseye PCU-1 Software
Innovate wideband O2 sensor with hand held monitor
Innovate Aux box data logger
