Thirdgen LS1 Head And Cam Swap
  • [Project] Thirdgen LS1 Head And Cam Swap
    Well I have been working on my car this last winter and into this spring and looks like it might be going into the summer. Last summer was the first year I got my car back together, so I figured, why not pull it all back apart and start over again, kinda. In the quest for more power and looking for a quicker destruction of the 7.5 inch heavy duty rear end…..let’s put a bigger cam and a nicer set of heads on that ls1
    So the engine creation is as follows:
    Cartex Stage 2X ported and milled 243 heads with 921’s
    Comp XER 230/236 .615/.620 On 113
    Slp Timing chain and Oil pump
    LS7 Lifters and ls2 Lifter Trays
    Hardened 7.350 Pushrods
    Yella Terra 1.7 Rockers
    Racetronix 38Lb Injectors
    Had on last year:
    LS6 PCV cover
    Under drive pulley,
    Weiand intake mti TB
    160 T-stat
    I am hoping to be able to get a fast 92 set up if I can afford it. I also had the hawks stainless swap headers and y-pipe jet hot coated in the steering extreme, It came out perfect and hopefully it will help with the under hood temps. Also got a tick clutch master cylinder that, I am going to try to make fit a thirdgen. Few other things going on, heres a few pictures and I am sure there will be few more to come.
    When I put the valve train together first I check ptv clearance, lots of room left, measured pushrod length came up with 7.300 inches with a solid checker lifter installed so ad the .50 for preload, 7.350 pushrod. Did a rocker arm pattern check on the valve steam, no shimming of the rocker arms required, the pattern came out on the center of the steam and narrow.
    Come on slacker...get that beast back together so we can do some cruizing
    Man those headers look awesome coated....what did that set you back?
    Send me the specs on that old cam you pulled out if you haven't sold it yet.
      Looking great Chris!
        looks awesome..nice job
        99 Buick Regal GS- New DD
        SOLD-1967 Buick Skylark
          Wow that looks great!! Keep us posted!
            Party!!!! I got more work done on the car. Engine is back in, reinstalling everything. Rewired the fuel pump, no more crank for an hour. I also installed a racetronix fuel pump hot wire kit. I ran all the wires for the gauges I am putting in the car and anther relay for a second cooling fan. The inside wiring I still have to take care of………
            I also got the fully redesigned big ass Tick Performance aftermarket clutch master cly installed. So this thing is huge compared to a stock 4th gen master. So how does it fit in a car that was never made for a t56 clutch hydraulics, surprisingly well. The angle the rod comes out the cly and to the pedal is better then before. Just some redesigning my inside brackets and it fits.
            I’ll get some better pictures of the engine back in the car this week end, hopefully I can start it this week end. But it looks like I might not be driving the car for a while….more to come on that
              looks awesome.. tons of room...
