hes some more pics some through the nostril of the hood to show hood clearnace
89 camaro 5.3 swap
InActive Member
- November 19th, 2006
- 527
- dustin
- 1989 camaro rs, 2002 gmc sierra 1500,1999 chevy tahoe 2dr lifted
- rothbury michigan
- automotive technition
InActive Member
- 527
- dustin
- rothbury michigan
thanks but im going to use the truck intake it clears and i was told what i already knew that the truck out performs the ls1 intake. plus i have truck accessories already and they clear . but thanks anyway.
Originally posted by sman View PostI just picked up my complete ls6 intake. So I have an ls1 intake with car injectors, rails, and TB that id be willing to let go for cheap(when I get it off). Also if you just pick one up yourself you can use the truck TB with one easy quick mod, less than 60 seconds to do.sigpic
A wee bit tight in there isn't it?
Have you considered engine rock under load?Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
InActive Member
- 527
- dustin
- rothbury michigan
every place except the map sensor has atleast 2 inches of clearance, i have poly mounts and my 350 didnt rock hardly at all so i should be fine.sigpic
Where did you hear this?Originally posted by alwaysmessedup View Postthanks but im going to use the truck intake it clears and i was told what i already knew that the truck out performs the ls1 intake. plus i have truck accessories already and they clear . but thanks anyway.1999 Camaro - 6 liters of fury.....
InActive Member
- 527
- dustin
- rothbury michigan
InActive Member
- 527
- dustin
- rothbury michigan
i built my own mounts using the stock small block mounts and s and p plate design, they sell the plates for 40 but i had my dad machine some up for me for free. i did have to move the motor mount on the crossmember back an inch and up a 1/4". you can buy all kinds of different mounts. i decided to do it this way because i have brand new poly mounts for my small block that was in it so i could see spending 160 for 4th gen poly mounts then 85 for conversion mount. here are some pics.Originally posted by Rubidon View PostWhat motor mounts are you using? I am doing the same build!! I would like to see more pictures as it progresses so I know what I will run into. LOLsigpic
Where did you get the drawings for the motor mount plates? I know I have seen them on the web some where but I can't find them now???? Found one on ls1tech. How much clearance do you have from your firewall? Did you have to modify your k-member?Last edited by Rubidon; January 10th, 2010, 11:38 PM.
InActive Member
- 527
- dustin
- rothbury michigan
http://matt.undiagnosed.org/ls1/imag...ount_plate.jpg this is the link some of the info is wrong, as you can see in my middle pick the 2 bolts in the small block mount that have silver washers these holes are drilled and taped to 3/8 24 thread and the bolt inbetween them is supose to be countersunk but i just drilled a hole in my small block mount to go over the bolt. hope this helpssigpic
I may be interested depending on what you consider cheap?Originally posted by sman View PostI just picked up my complete ls6 intake. So I have an ls1 intake with car injectors, rails, and TB that id be willing to let go for cheap(when I get it off). Also if you just pick one up yourself you can use the truck TB with one easy quick mod, less than 60 seconds to do.
just to let you know I am half Dutch
You only have to notch the k member if your running a/c. Other than that you dont have to. You do have to relocate the brake line that runs on top of the k member. I just bent it so it runs behind the k member btw the k member and the oil pan and it fits perfectly!Originally posted by Rubidon View PostHey Dustin did you mess with your k-member? I heard that if you use the stock one you have to notch it?- 1988 Camaro IROC-Z
2000 5.3L | 4L60E | CAI | No EGR | No Cats | 85MM MAF | Tuned by PCM 4 LESS |
2000 Camaro Dash | 1996 TA Console |
- 1998 Monte Carlo Z34 (DD)
3.8L w/ 180xxx miles and going strong!!!!!
