Xmas mods for plum 95
    Not sure if the pop up headlights changes anything, but I just pulled my headlights and did it through the top on my car, way easyier than trying to do it from underneath.
    And IIRC, 93-97 birds used the same front markers as all 4th gen camaros. It was in 98 that the birds got a new design that differed from the camaros, and the use the std camaro REAR marker light on the front sides of the birds with a totally diff design front facing marker.
      well it was worth a try lol, I plan to try the nite shade mod before I buy clear just to see which I like best but I don't want to mess with my original ones.
      Sounds like a nice Christmas and hope all goes well
        Very nice! Keep up the good work Larry!
          93-97 firebird front markers only fit 93-97 firebirds
          my friend had a 96 camaro with clear markers and before buying my markers i looked into swapping them off his car because he was going to sell it...THEY ARE NOT THE SAME
          it is proly best to go through the bottom, it is just one plastic panel to remove to get to them underneath
            I did the same thing with mine. I tried it through the bottom once. PIA in extremes. If there's any kind of oxidation on the screws underneath, you'll risk spinning the clip when you try to unscrew them, cutting the plastic. Usually, when I do any work where I need to remove them, I just remove the headlight bezels and spin out the three screws holding them in. No crawling on the ground, cutting your arms up necessary.
              X2, those clips on the bottom are a total PITA, they seriously need to come up with something better than that.
              Can someone post a good picture or some firebird corners? They look identical to me.
                they measure 12.5 " long and here are pics. or look on ebay also
                  When you compare them close-up, you can see that they're very different.
                  West Michigan Pontiac Club
                    I would definitely choose a Hurst over pro 5.0
                    They seem to be nicer, plus my throw isn't very short, suppose I could fix it by cutting it though.
                    Used to own a Firebird.
                      Gotcha, didnt notice how the birds were square on the trailing edge.
                          ya larry have b get you a hurst shifter for your birthday now
                          seriously tho i swear by my hurst its so nice. im liking the shift knob alot tho, i have same one but in white and it looks out of place in my car
                            Sweet Larry... Clears will look bad ass..
                                schaweet!! looks great
