I even went to school with the kid. They steal Honda's left and right and I knew once I tossed wheels on it, they would come. And sure enough they did. They must've shit their pants when they got halfway down the street and seen my handgun permit sitting on my passenger seat and realized it's slow as balls. But yes, I will take them down and something will happen to them.
Fred you can race it tonight around 2am. I'll just need to swap motors real quick.
Block is notched for the rods
.0004 Piston to Wall Clearance
Block was bored to fit the pistons perfectly
75.5mm YCP Vitara Pistons
FJT Custom Length Rods
Polished Crank
Chamferred Oil Passages, and Coolant Passages
ARP 5000 Rod Bolts
ARP Head Studs
Decked Block
Ported, Polished, Shimmed OEM Honda Oil Pump
OEM Honda 3 Layer Headgasket
OEM Honda Oil Pan Gasket
OEM Honda Oil Pickup Tube Gasket
GlowShift Oil Sandwich Adaptor
HAMP Small Oil Filter
JB Welded Barbed hose for a PCV Breather
Tapped Oil Pan with Oil Return
Magnetic Oil Drain Plug
Magnetic Trans Plug
Poly Motor Mount Inserts
OEM Honda Rear Main Seal
ACL Bearings
OEM Honda Thrust Washers
Ported and Polished Head
Delta 272 D16Z6 Cam
Z6 Valve Springs and Retainers
Block was machined, and assembled by Champion Racing Engines. Everything was gone through to make sure every clearance was perfect. Even the ARP Rod bolts were lathed to bring the clearance down.
The head was hand ported, just cleaned up the casting marks, and polished the bowls. I got my order in from Honda the other day with the valve seals and everything, I also got my cam sprocket, timing belt, etc... Time to take it to get assembled.
Hopefully this spring if I don't steer away from it again. After the head is assembled, I just need a clutch, and misc. odd's and ends, including a turbo.
