Thanks for filling us in ang, I was getting antsy.
Meissen's LT1 Rebuild Thread
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
Any updates??
I'll post pictures and then text...
I mean, I just, I don't even know what to say B. This sucks big time man. Im sorry for your loss.
man we did some good work b and larry and craig!!The Original
Alright - so we started working at 10am and finished about 11:30pm. We only stopped for dinner, otherwise we just kept going. We had the engine out by 5 or 6. Then we tore down the block with a lot of messing around and fussing with the engine stand and cherry picker. We also made a freaking mess with the coolant and oil all over the place. Had to lay cardboard down when we were done because the floor is so slick.
But anyway, the damage... we only pulled three of the main bearings to check them and you could smell a "burnt" smell as soon as you cracked each bolt loose. All of the ones we checked were either really damn worn or spun.
So, looks like we're going to have the cylinder walls bored out, new pistons, new rings, new rods, maybe new crank or atleast machined, new bearings, etc. Thankfully the cam looks pretty good from what we could see from the bottom end. But yeah, chunks of metal from the bearings, metal shaving/dust all over in the oil pan... it's toast.- Brian Meissen
ouch !!!!!!RIP Doug,You will always be remembered
3/3/53 ~ 12/22/10
1985 Camaro IROC-Z
1974 Camaro Type LT / Z28
2002 Trail Blazer LTZ
1996 Camaro SS (Sold
www.wmcamaro.org
Brian, sounds like you have a pretty good plan laid out there. However, I would question using the same cam. Not so much because of the cam itself, but the rest of the valve train. I spent nearly 30 years working at the GM/Delphi plant that makes those valve lifters. They have extremely tight tolerances internally (just a few microns) and won't take well to any type of contamination. Further, they have needle bearings at the roller, another place where metal particles would not do any good. Just replacing the lifters and putting new roller lifters on a used cam may not be the best policy either, as a wear pattern has already been established.Originally posted by meissen View Post
So, looks like we're going to have the cylinder walls bored out, new pistons, new rings, new rods, maybe new crank or at least machined, new bearings, etc. Thankfully the cam looks pretty good from what we could see from the bottom end.
Did you upgrade to performance rocker arms too? They also rock on needle bearings. The oil pumps through the valve lifters, up through the push rods and out onto the rockers, making them vulnerable to the metal particle contamination as well. Especially damaging to these parts are the metal particles you can't see (of the micron size).
I would have your engine builder take a look at the rods. You may be able to reuse them. The rod bearings will get replaced anyway, and if you bore the block, you'll get new pistons and piston pins. If the new pins fit the old rods within tolerance, they should be reusable. The area of piston pin and rod connection is not nearly as fussy a place as the valve train stuff I mentioned above.
Don't forget to check the cam bearings too.
Good luck and keep us posted (I know you will. LOL)
3/3/53 ~ 12/22/10
1985 Camaro IROC-Z
www.wmcamaro.org
Well, we're going to be soaking everything in mineral spirits for awhile to try and clean them out but the cam looks pretty good and with only 100 miles on it it's hard for me to throw that money away... The top end looks great, it's just the bottom end that's all effed up.
Dunno, we'll see - all depends on what we find when we start taking it down to the bare block.
I forgot to mention - on a positive note the burr that was in the driveshaft was gone and now I finally knew what y'all were saying about the driveshaft moving freely in and out of the tailshaft of the trans.- Brian Meissen
man that sucks brian, you thinking of going 355?2011 Ford Raptor SuperCrew
I just kept scrolling down and every pic brought on another little wince of pain...
Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Either 355 or 383. Pretty much has to be bored to a 355 either way.Originally posted by s.reef View Postman that sucks brian, you thinking of going 355?
Yeah... what sucks the most is I have no one to blame but myself for it.Originally posted by 81DaytonaPaceCar View PostI just kept scrolling down and every pic brought on another little wince of pain...
this is making me sick, between your car and Ricky's and then Spencer saying his lifters may be bad I am scared to get my car out and running this week. Don't worry though Brian you and angie will just have to put some miles on her bird this year, now go take a few days off and relax with a cold one.Doing less with more
