Project Never Fast Enough
    Ok guys here an update, the heads are back and I couldn't be happier with how they turned out have a look and see what you think.
    Before
    After
    Also I wanted to show you guys a few other little projects I have going on that are helping me to cut cost. We have a blast cabinet at work so on my lunch break I tried to blast off my headers quickly, I still have to finish the job but once these bad boys are done I'll be coating them with POR 20 and possibly even curing them in an oven before they go on.
    Another huge cost saver is my FAST 90 intake. When I first got the intake about 3 years ago my buddy "sold" it to me but didn't include the new valley cover bolts that came with the intake. Therefor, when I first started torqing down the intake it cracked and caused a whole big mess which totally bummed me out. Remember this intake costs $900+ brand new. Luckly FAST sells the 3 individual parts of the intake seperate if you choose, but I didn't have time or cash for the $360 bottom half that I just cracked so we got a few ideas together and decided to epoxy a piece of sheetmetal where the crack was and completly removed the broken plastic piece. This worked great for the last few years but upon inspection this time I noticed that the epoxy was starting to flake off pretty easily now so we went back to square one. I did some searching and found a place in Detroit that does plastic welding, drove out there only to discover that because the intake is poly that its composed of many different plastics and he could not get any welding rod to stick. The guy did howeveer suggest my backup plan that I had.
    My backup plan was to use JB weld, as the epoxy I had was not intended for plastic use and JB weld was also what FAST and several guys on LS1tech had recommended as well. One of these such guys used it on his own intake which saw 20lbs of boost after and had no issues whatsoever. Like always though I had to improve upon this somehow so my Dad got a great idea to make a piece of aluminum that was cut very thin on the outside and had a stepped inside that was about the same size as the hold in the intake. Meaning if the JB weld built up on the inside were to fail there would not be a massive leak causing possibly a fire ect. the plug could not get sucked in either due to it being bigger on the bottom of the intake. If this is all confusing here are a few pics.
    Also note that we discovered another hairline crack toward the front of the inatake, after we snaded it down a bit we noticed that it grew quickly and definatley had to be leaking before which obviously must not have been great. Anyways feel free to leave me any comment of suggestions on the whole thing.
      Originally posted by WMCCjames View Post
      Awesome thread man....MiFbody needs more of these.
      x2...great thread...
        Pretty interesting using the JB Weld, Jeff. How thick are you applying it? Looks thin in the pics. Only curious because in my use of JB Weld it works really well but it can also be brittle at times.
          looks like some great progress - loved the vid
            Its a pretty thick layer on top although the plastic the intake is made of is only 1/4", the bottom just has a nice bead around it because I can't have it real think there as it'll contact the valley cover bolts again lol. The JB weld actually seems to hold very well so far its just all in the prep work, everything is sanded to rought it up a bit and then wiped clean with laquer thinner or acetone and after the JB weld is applied the longer you wait the better, we wait a few days and then we'll build up some more. When its all said and done I'm gonna sand the inside smooth and maybe spray bomb the bottom after its all blended.
              Yeah, I'm interested in how the JB Weld holds.
              When plugging the silencer holes on the M62 supercharger on the Cobalts, the #1 No-no was using JB Weld, they recommend using Quiksteel or something of the like.
                Awesome pics and build! All these build threads lately are making me jealous!
                  You also have to figure the intake isn't seeing much vacuum like a supercharger would see. I figure that is why the old epoxy held so well and trust me this JB weld is holding much better already. I also would never consider spraying the car or boosting it with this but it should work fine N/A until I wanna cough up more $$ than an LS6 intake just for the bottom.
                    That's also a good point.
                      Did a few more things today. We installed the windage tray and then the new Melling oil pump I got. After that we installed the oil pickup tube with the new piece I bought off a LS1tech sponsor which allows you to use both bolt holes in the pump and creates more even clamping force so the pickup tube o-ring doesn't get pinched. After that we installed the oil pan and torqued it down. Its not awaiting the new cam and then we can keep going on the resurrection. Heres a few pics.
                        Lookin good!
                        Where are you doing the work?
                          cool! Let me know when you need an extra set of hands!
                            God this car is going to be my dream car when you are done. Looks like you are making some progress, keep up the good work
                              very nice thread. unbelievable how fast that car is. im definately doing something wrong
                              - - 5.3/4L80e/T7875 - -
                              - Huron Speed Turbo Kit -
                              1998 Formula
                                Looking good. Another option to the JB weld maybe is Weld-On...its an acrylic glue that is used to fuse acrylic/plastic panels together.
