POR 15 Question
    how about local suppliers?
      a body shop just north of greatlakes crossing sells it
        finish master..
          Originally posted by Boost Addict View Post
          DO NOT buy the gallon! You will have to put it all in a seperate container once you are done using it unless you are very careful not to spill any on the can. It is very difficult to get a can open once you have gotten then paint over the can. A little bit of this stuff goes a long way. I see you not needing more than a quart.
          The secret is to put a plastic baggy over the top of the can before putting the lid on. 1 year after I opened my can, I opened it and did the bottom of my lawn mower deck.
          2011 Camaro SS
          1999 Camaro SS #4153
          1986 Monte Carlo SS
          1969 Camaro - 427 Rat
            So how much prep. time should i invest before por-15 on? Just get the loose stuff off and just give her a good wire brush down and then should i be good to go??
            -Guy that have used por-15. Should i just go over everything like the brake lines and brackets and all?
              Justin off the top of my head I cant think where's finish masters at?
                POR likes rust, I think it sticks to it better, I wouldnt bother with the wire brush, I'd just get all the dirt off of there and stuff like that. And I would just put it right over the brake lines and other stuff.
                2015 Silverado
