  • Depending on the size of mine, I think thats what ill do also. Did you get one from mike? Got dimensions/pictures?
    Hey isnt that in out tutorials too?
    • What's the plan then B?
      • You guys can really mount the trans cooler anywhere you think it'll get lots of air, most people do it in front of the rad/condenser. I have mine mounted under the drl on the passenger side.
        • LOL hahah good luck brian its a ***** Cutting the tabs that fasten through the radiator and it was also a pain to get the zip ties to go through.
          • Originally posted by sman View Post
            I bought mine from Creight. Only problem was that it doesn't come with ... well, anything. I bought the zip tie installation kit too, but I have to get my own connectors and hoses to get it installed.
            http://cs3automotive.com/index.php?a=PROD:1379
            Finish and then start it. I'm not putting a deadline on it but I think this time next week it should be running. I got too caught up trying to make the deadline that I started to want to cut corners and I can't do that. Going to do it right, even if it continues to make me broke.
            Yeah, that's what Mike was saying. I just want it somewhere that will be safe and won't get damaged. Mike said he's heard of people putting them inside their bumper (like... in the fender side of the bumper where there's absolutely no air flow).
            • Well I'm happy to be back to work! Brian promoted me to "cheif of pitcrew" got lots to do today my boss Brian is a real slave driver, but with every promotion we all know is more work and responsibility. LOL
              • its coming along before you know she will come to life.. hey b i got 4 dollars..... you think i could get a little something
                • If it starts with an M and ends with a 6, no.
                    Glad you finally got promoted larry! "Cheif od pitcrew"
                    • Soon enough he'll go from Chief of Pit Crew to Owner/Operator (he's already got the first part set! )
                      • Ordered the spring seats (THANKS GARY!!!!!!) and the LT1 PCM connectors.
                          i think its time for you to unionize
                          then go on strike
                          • Originally posted by TSTONE View Post
                            then go on strike
                            So if Larry is the Pit Crew Chief does that make B his side kick
                            • FWIW Brian, on my Trans Am I ran a trans cooler that was by itself. I ran earl's braided lines from the transmission all the way up to the cooler and then back right to the trans. I mounted the cooler right up front with a custom bracket and cut out my license plate area and it mounted vertically so it was right at the nose of the car. The brackets made were welded right to the metal bumper support.
                              • Do you have a link to the earl lines you're talking about?
                                Here's some progress pics from this weekend and the past couple days. We've been doing a lot of little things. Yesterday I went through and reran some stuff so it'd be cleaner looking, and today my dad did some polishing and other work. We're mostly waiting on my automatic radiator to arrive.
