Having a hell of a time finding the info I need... My 383 lt1 I'm switching from the f1a to the 7875 turbonetics. My question is, oil feed line and restrictor size. I know with ls1 they run 4an with a restrictor. But LSx at idle run a lot more oil pressure than us LTx guys do. My OFI kit I bought came with a 3an feed.. I think this is too small... What restrictor should I be using and what oil pressure needs to be seen at the turbo. The drain size I'll be running is a 10an. But I don't want to over oil ( push oil into the inlet) or under oil (burn up the turbo).
2nd. Without removing the motor... I need to tap my pan... I have a canton pan. I was just going to use the supplied 1/2 npt fitting on the top of the wing, but they don't make a 1/2 to 10an fitting. And I thing the 1/2 npt won't drain enough anyway. This basically my biggest bolt up of finishing the turbo swap! 50 bucks worth of lines and fittings stand between getting this kit done and staying on the jack stands.
