Nano nitrous installed
  • Nano nitrous installed
    I finally have my nitrous kit installed after spending the past couple months chasing electrical problems and leaking fittings. I bought a plate kit this spring and decided to put a nano kit on it instead of a bottle heater. i put my nitrous bottle in the spare tire area and the nano bottle is on the deck. I put in a racetronix pump with hot wire kit to handle the extra fuel load. I'm running a 100 shot and im using a timing tuner to pull 6 degrees. I'm using a 52 nitrous jet with a 30 fuel jet and I've attached a picture of a plug after a wot pass. I think it may be a little lean on the 30 fuel jet, but it looked too rich on a 31. I may leave the 31 jet in and up the nitrous to a 54 to see if i can find a good middle ground. The car pulls strong and gear changes come much faster, but I'm excited to see how it runs against some other cars.
    CAMMED M6 (375RWHP/371RWTQ)
      Looks good Chace!!!
        Chace - looks good. It's hard to tell in that picture if it's a shadow or a tan fuel ring.
        2000 Formula
        fixed slow junk
          Glad to hear you like it! Make sure to let us know when you run some numbers..
            It's hard to tell from the plug picture, but there's a light tan fuel ring on the base of the porcelain. It's pretty light so I wasn't sure if I was getting too lean.
