ok guys...countless hours reading post from up to 7 years ago...head is spinning..lol. i'd appreciate any advice on what i plan on doing.
here's my plan, tell me if i'm doing it right. 94 383 vortech/aftercooled, maf is on the blow side near throttle body. i plan on leaving the stock pcv valve (driver side intake) intact. on the tube from passenger valve cover to throttle body, i plan on running a hose from that valve cover fitting to an oil/air separator (husky one from home depot #401910) and from the separator to the intake/suck side of the vortech intake pipe. i will also plug the hole on the throttle body that was connected to the tube from passenger side valve cover.
i know not the most efficient setup, but hoping it would work for the time being to relieve some crankcase pressure under boost. another question i was wondering about, since it is maf metered air and not running a speed density tune, would the tube running from the passenger side valve cover >> separator >> blower intake suck side tubing matter since the air was already "measured", i would be re-introducing metered air back in front of the maf, would that really affect anything (if that makes sense)?
appreciate it guys...thanks!!
