Huron Speed 98-02 Single Turbo Kit
  • Huron Speed 98-02 Single Turbo Kit
    Huron Speed 1998-2002 LS1 F-body Truck Manifold Single Turbo Kit
    Here it is! Should be ready to ship here shortly, but this is the final version!
    View it on my website here: http://shop.huronspeedproducts.com/F...FBodyTurbo.htm
    This kit is MUCH more complete than your run of the mill Truck Manifold kit. Comes with the complete hot-side, cold-side, all couplers, clamps, brackets, flanges, gaskets, etc as you can see from the picture! Kit includes all components to run either the 38mm or 44mm Wastegate, as well as to run a MAF or not!
    I will copy on over what all is included for an easy read:
    Includes:
    -2.5" crossover with T4 flange and 38mm Wastegate Flange
    -38mm-44mm Wastegate Adapter Flange
    -3" Downpipe with 3" V-Band flange
    -3" Cold side piping from turbo to FMIC to Throttle Body
    -MAF Delete pipe
    -50mm Blow-Off Valve Flange on Cold side piping
    -4" core front mount Intercooler
    -All exact, specific couplers
    -Extra exact couplers to run or not run the MAF Delete
    -All exact, specific T-Bolt clamps
    -F-body front mount intercoolers brackets
    -F-body alternator relocation brackets
    All piping made from 321 stainless steel, fully polished.
    Requires Turbo, Wastegate, BOV, Oil Lines, and Truck Manifolds to complete
    *Pricing is not finalized and is subject to change before initial sale is launched.*
    looks like a cool kit. been working on it a long time! i'm interested to know the price.
      Thank you! There have been a lot of changes to make it as best as possible to cater to the most amount of people as possible. Recently the BOV location has changed as you may note. (Previous location was too cramped). Also the MAF delete pipe is now included for those wanting to go Speed Density and have a spot to spray meth/add your IAT sensor or you can still run straight to the TB for the ultra clean look.
      Waiting to receive all my final costs and then I can figure that out! Initial orders will be for the first 20-25 and will have discounted pricing Also will have the ability to add a 38mm or 44mm wastegate, and/or 50mm BOV to add to your kit! Working on also getting a turbo option to add as an option as well
        Id also like to add that this kit allows the factory radiator location to be used. you do not have to cut the core support and stand up the rad. You do however need to use pusher fans. If needed we can recommend some for you.
        -Casey
        Huron Speed Products
        -98-02 Single Turbo Kit
          Looks quality. Should be alot of LSx owners that'll be happy when it's completely resleased.
            -Casey
            thats definitely a good thing to advertise. that was a PITA for me to cut it, get a radiator and fans to work. and it still looks like crap are you guys going to sell a fully complete kit with the manifolds, turbo, bov, wastegate, oil lines, fittings and instructions? just my .02 but that might be able to sell better. maybe on my next ls1 car i'll just buy a kit from you!
              Yes, it will be sold as you see it above, with the other components available from a drop down menu to make it as complete as you wish. This way you can get it as basic as you want if you want to piece it together or use your own components, or as complete as you want!
                Looking forward to seeing how it runs Casey, are you sticking with the 6 spd?
                  pretty sure he went th400
                    they always do! better than a 4L60e though
                      Pa-leaz
                      http://youtu.be/nv8tD_zhlAg
                        yeah.. that right there is a super high dollar 4l60.. cmon larry get real. you know its way cheaper to build a th400 then a 4l60e
                          truth. but I still have one lol
                            Point is moot, kit will work with 4l60-e, th400, t56, any.
                              yes the car will have a th400 in it for now. at the time, i couldnt afford to build a t56 for what i wanted to do. so i made the decision to go auto (it was REALLY hard for me, ask jon) eventually i will build a more purpose built "Race" car and swap the auto from this car to it, and put a manual back in. but for now, auto it is!
                              plus sean is gonna sell me his 9 inch cheap so i can make this thing 60'!
