That is a mystery, I would guess low 10's on spray.
Personal Best
Originally posted by my1994z28 View PostSince I pretty much laid my cards on the table,as to what my car ran..What does his car run?
Ryan will never say on here what he runs....
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
^ You should probably think about updating your sig! ^
lol ill try and keep it on topic, as for the brakes i completely changed my whole brake system last summer, every line and every hose was changed and every caliper.. i also converted to the braided stainless steel lines for the calipers, anyways i went to check my trans to make sure it was going to work properly(did the 60e swap) and got it going in reverse and couldnt stop the rear(on jack stands).. long story short my car doesnt make enough vacuum(my small cam
) after u get the rpms up it will stop fine but once that vacuum is used in the booster good luck. i bought a vacuum pump and should fix my problems. if not i blame it on my ford brakes
hope this helps.
97 TA AI 355
2012 Jeep Patriot
Not an excuse, just about everyone managed without overdrive in the 60sOriginally posted by 1BADAIR View Posthave to have OD. gets driven almost daily
