Do you think a v6 camaro can use a commodore v6 Ecotec supercharger? I know that you can fit a commodore manifold because 97rs4life did it so my question is can you do the same but with the supercharged manifold? http://mifbody.com/vbulletin/showthread.php?t=19820 thats 97rs4life
i dont see why not, im sure you would have to use some of the bracketry off of the front to make it work right.
Based on the MINIMAL clearance my brother (97rs4life) has with his Holden intake, I highly doubt it.. He has a custom k member and spacers above the kmember just to get enough clearance for the intake. A supercharger on top of that would only be a dream IMO.
-Derek-
already checked into it and the dimensions of it make it so it wouldn't work without serious fab work. The height isn't an issue, it is the dimensions of it off the back of the engine Also the power gains from it are not worth it when you can go centrifical or turbo and make more power.
There are a couple guys running around with the gtp sc on their fbody cars but it is not a simple bolt on either. You need to hack up the supercharger to turn the inlet back to the front of the car. It can be done, but the fabbing needed and the power you gain from those sc's make it really not worth it. Unique factor high however.
