nitrous installed ? about the gear
  • nitrous installed ? about the gear
    i just hooked up a 100 shot on my TA and plan on taking it to the track this weekend.. i have a few questions i have 4.10 gears and right now i trap the light at like 5800-5900 in 4th so if i end up using some spray i think i will have to be in 5th then? if so can 5 gear hold up to nitrous? i know its a overdrive and i have heard you shouldnt really put too much power to them.. but i just wanted to know weither i should spray 3-5 or just 3 and 4th.. thanks for any imput..
    97 TA AI 355
    2012 Jeep Patriot
    Larry(1BADAIR) will chime in shortly I'm sure.. I run a A4 on spray, so don't have a clue on 6 speeds.. Good luck at the track and post up some vid and times!!
      ill try its sopposed to rain which would really suck!!! but i am hoping to hit high 12s..
      97 TA AI 355
      2012 Jeep Patriot
        What kind of system, wet, dry, plate, window switch, etc??
          NOS universal wet kit.. i have it set up on a wide open throttle switch so it should be interesting.. because i cant spay untill 3 or i will just spin.. i havent used it yet becuase i am sill in the process of getting a custom switch panel made for it.. then i will be all set.
          97 TA AI 355
          2012 Jeep Patriot
            try it and find out... thats the easiest way to see if it works
              your trap is at like 110? you can use 5th, but .74 ratio isnt what your wanting. and i hope on a manual ur not bouncing limiter with the spray and have a button WOT and push button or window switch
              just a bolt-on Lt1
                at that power level 5th should be ok.
                I don't recommend using n20 without a window switch on a stick though.
                bog and boom, hit the limiter>boom
                  youll be fine, ive personaly never seen a bolt on LT1 with a 100 shot need to hit 5th even with 4.10's. hell i never had to in my old SS and that was a 150 shot and a 355 and you shouldnt spray the car under 3000rpm anyway, LT1s dont like that
                    what size tire r u running?
                      25.6s i took the car out last night and sparyed it.. it was alright but i thnk something isnt right becuse it kindof hesitates like it needs fuel or something.. i am going to take the fogger out and see if its semi plugged and make sure that i am getting fuel in the mixture also.. then sunday if the weather is nice i am going to see how much its helped!!
                      97 TA AI 355
                      2012 Jeep Patriot
                        ive ran a couple differant sizes with no issue, from a 26inch MT ET street, to 18 inch Y2K vette wheels, my buddy ran 17inxh ZR1s and still never had to hit 5th.
                          alright.. sweet now i just have to get the nitrous working properally
                          97 TA AI 355
                          2012 Jeep Patriot
                            whats your NA mph?
