Steel braided blow down question
  • Steel braided blow down question
    Anyone know where I can get a kit like this?
    http://www.dynotunenitrous.com/store...p?idproduct=86
    For some reason they say it won't work on a nitro daves bottle, even though it has an 8 AN fitting.. I found a kit made by zex, but they want 110 bucks..
    http://www.compperformancegroupstore...OMPFittingsFLA
    i cant see why it wouldnt; work. as long as you have a -8an fitting on there it should work...
    if you buy it and it doesn;t work tho i will buy it off you b/c i would much rather have that one then the one i have
      I emailed them and asked why it wouldn't work.. We'll see what they say..
        some of the blowoff valves hit inside of the AN
        I bought AN fittings and made my own
          just an idea but what about a braided plumbing line (for sinks) maybe even with hand tighten nut like the 860 blow down I'm using.like I said just an idea and alot cheaper.
            Yeah great idea, If its a safety vent doesn't seem to have any real presure on it. probably fab your own for 10-15 bucks.
              Oh but it does. up to and over 1000 PSI... Even though it would not have to hold that pressure, it would still be alot of pressure going through a line not designed for that amount of pressure..
                if its why I think it won't fit you can change the blow off too
                  It will work, I have a female adapter on my blow off valve. Unfortunately I am impatient and just bought the other kit before I got a response from the first guy.. DOH!
