Thinking of putting my car back on the bottle(and using it this time), would like your opinions on this kit? Besides a window switch is there anything else I may need? http://cgi.ebay.com/ebaymotors/NITRO...spagenameZWDVW
I wouldn't go with any company that is not well know you never know what your buying. Go call Nitrous Dave's outlet and he'll hook you up with everything you need
I think I'm going with a NOS or NX Express on mine. The bottle is going to be hidden but I still think I'm going to get it painted and have a buddy airbrush red/maroon flames on it.
1999 Pontiac Trans Am- LS1 - M6 - ITSSLOW - 12.998@109.59 - SOLD
1994 Chevrolet Camaro - 3.4L - M5 - ITSSLWR - 16.558@85.38 2003 Chevrolet Blazer
if nos is really the way u wanna go ( i wouldnt) then i wouldnt do more than 50-100 shot or youll be finding yourself with a nice blown motor, might even still, gotta becareful with the stuff, the switch on the console aint exactly the best way to go, hard to regulate the flow and cut off time that way unless its got a comp hook up in it, just do the research before useing any nos.
Mods: Ram Air Intake (CAI)
K&N Filter Polished Throttle Body and MAF Sensor
De-screened MAF Sensor Tightened Throttle Body Cable
Performance Button Setting Changed for Torque 160* HypterTech Thermo
Water Wetter New Distributor, Plugs, Wires
New Water Pump LT4 Knock Sensor Flowmaster 40 Series Muffler TB AirFoil
I would suggest going with a wet kit from nitrouis express. If you are running a stock engine you are good up to 125 hp. There is nothing wron with spray as long as you understand when to use it. Don't let people tell you there is more risk to spray then turbo or supercharger. They all have the same problem "Detonation".
Yep people that don't know about Nitrous are the ones afraid to use it, just make sure you get everything. IE window switch, bottle heater, purge kit, ect. and make sure its properly tuned.
I also would recommend NX. I ran their maf wet kit on my lt1 all summer. 125HP shot on stock motor with no problems. I didn't see if the kit came with a WOT switch or a bottle heater. For extra safety precaution you could upgrade the fuel pump.
67 Coupe Corn fed 502BBC 4L80E 371WHP/367FT lbs torque
70 Pontiac Lemans Vert, GTO clone, 427BBC and 7000R4
I bought my kit from speedtweekz it was drop shipped from NOS. took a little longer to arrive. like they said the window is a must. also look into MSD digital 6. it will retard your timing fully adjustable. finding out there is not such thing as an inexpensive nitrous kit. LOL DJ
