So Magnuson has been getting some press lately about it's new 1900 series high-helix blower and rightly so. These things make dirty quick boost and are very efficient. Hot Rod did one on an LQ9 and Car Craft made 510 hp on a run-o-the mill 350 carbed motor.
Here is my thought: I have a ProCharger that makes mid and upper hp and boost, so why not add a positive displacement supercharger like the 122 Eaton unit to make up for the ProCharger lacking low rpm boost?
Would I see the Eaton boost off idle then also see boost climb as the ProCharger kicked in?
Or would the ProCharger "short cut" the Eaton out of it's efficiency and not make as much hp as I expect?
Would the Eaton still "positively displace" the ProCharger's compressed air like NA air?
So many questions my engineering mind has, someone go test this now!!!
The Eaton has it's own intercooler as does the Procharger. Add some alky injection and it'd be cold as ice! (willing to sacrifice....Foreigner rocks!)
It'd be an easy install since they run off different belts and the Eaton has a TB and all the applicable sensors.
Both would make for one SERIOUSLY pissed off 305!!
Thoughts?
Thoughts?
