Hey all you detailers....what are you guys using to remove wax from your car's finish? I use denatured alcohol but was looking for something more wallet friendly.
Wax remover
I've heard Windex or Formula 409.
Never tried it though...Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
I usually just wash the car, claybar it, then go through with my detailing process of steps------------------------------------------
5th gen Camaro V6 Forums
http://www.bowtiev6.com
Dish Soap!!!
its a degreaser so it takes it right off and doesnt hurt anything.-Joel
what in the world kinda wax you using then? dish soap has removed every wax on contact for me.Originally posted by WMCCjames View PostDish soap doesn't do jack for me....unless I wash the car like 10 times.-Joel
Really...I just use NXT. I wash...water still beads up...wash again, water still beads....yadda yadda yadda....rinse and repeat. Eff this...wipe with denatured alcohol...no more beading water. Isn't that the test for wax presence...water beading?Originally posted by JoeliusZ28 View Postwhat in the world kinda wax you using then? dish soap has removed every wax on contact for me.sigpicTurbo Charged LS1/T56
yeah denatured alcohol definatly takes it off and doesn't hurt the paint, i use it for removing tree sap. Dish Soap SHOULD take the wax off, my question is why do you wanna take it off?1998 Camaro SS Bullseye Turbo
no no no!! water beading only means you have a smooth finish! Normally this recquires wax, but if your paint is in good enough condition it will still bead without wax! beading is only an indicator of how coarse the finish is, beyond what your eye will see. the rougher the paint the more the water will "absorb" (but not really) into it. Its physics and surface tension. Wax simply fills in a rough finish. One test I learned at work was to fill a plastic baggie with water. if it slides off the paint its waxed, if it rolls it isnt... or something like that, been a long time since i had to do that.Originally posted by WMCCjames View PostReally...I just use NXT. I wash...water still beads up...wash again, water still beads....yadda yadda yadda....rinse and repeat. Eff this...wipe with denatured alcohol...no more beading water. Isn't that the test for wax presence...water beading?Last edited by JoeliusZ28; March 28th, 2007, 05:48 PM.-Joel
Hummm...well after I wipe it with the alcohol the water kinda sheets off, there isn't much beading to speak of. The reason I like removing the wax first is because I like starting with a fresh surface...and believe it or not, with my car being white, old wax seems to take on a yellow hue and I can see it...call me crazy.
The car always looks brighter after the wax is off.
Good thread...really good thread...Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
I know what you mean, I clay bar my truck with dish soap every spring for that reason.Originally posted by WMCCjames View PostHummm...well after I wipe it with the alcohol the water kinda sheets off, there isn't much beading to speak of. The reason I like removing the wax first is because I like starting with a fresh surface...and believe it or not, with my car being white, old wax seems to take on a yellow hue and I can see it...call me crazy.
The car always looks brighter after the wax is off.-Joel
Originally posted by pheonix_rising View PostNick takes off wax too. . . lol
good one, I was thinking more along the lines of Gary though
