Tires Oxidized in Storage HELP!!!
    Yep turning Brown is probably caused by the products yu are using on them. I have used the Armor all gel that wade suggested and had good results also.
    — Thomas Jefferson
      I've used the armour all liquid spray and the tire foam. I've mostly used the foam and been using it for years. I've yet to have a problem with any tires on any vehicle I've used it on.
        Been using the Armor all foam. Oh well, I guess I'll just keep applying the product. I don't think I'll use tire dressing ever again once I get a set of new rubber.
          i hate it when the little excess coat you put on sprays up on your car, i mean i really try to get it dry but i never seem to be bale too, does anyone not have this problem and what stuff are you using. how long do you let it sit or cure
            Westley's Bleach-White should cure any problems your havin..
            I always scrub the tires down with it before applying the shine Although i very rarely use shine.. sick of cleaning it off my paint. For some reason no matter how long it dries.. it will never stay on at triple digit speeds.
              Apply with a cloth and it won't spray out all over your paint.....I've do it that way for years and have never had it get on the the paint no matter how fast you drive.
                well i dont know about the "no matter how fast you drive" part.. but for normal speeds... yeah
                  Well..I hit 120mph coming back from superfest lastyear.....got pulled over too.....lucky I had already started slowing down. Anyways..no splatter!
                    i apply it with a towel too and never have splatter
