Yeah, I only tried the orbital once, and I didn't even get all the way through it, was easier just to do it by hand.
Waxing Poll
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
- Mechanical Designer
GOOGLE is your friend.Originally posted by kammi10damn Ot where do you get all these pics
He's banging the bell but not the way it's suppose to be done!
InActive Member
- August 29th, 2006
- 1456
- Josh C.
- 1997 Z28
- Fraser, MI
- Electro-Mechanical Engineer
Ok Maybe you help me here a little, I always used a RO buffer to apply the wax/polish, let it dry, then use the RO buffer to remove it with a clean pad. When do you buff? while its still wet or after the excess is removed? After reading some of this stuff I think Im going to remove by hand from now on though.Originally posted by kammi10yeah apply and take it off by hand. only use the buffer to actually buff the carThe Chevy Camaro was built with a single purpose in mind which it executes flawlessly...Going very very fast in a straight line until your hair catches on fire.
when i am actually buffing i just use rubbing compound and then go at it with my special polish and lay a good coat of wax over top.
never used a clay bar on it but hoping to do so this year to make the white shine even more
InActive Member
- December 1st, 2005
- 1208
- Jeremy
- 1978 Pontiac Firebird Formula
- Dorr, Michigan
- Fence Installer
Holley 650cfm Double Pumper
Edelbrock Performer-Plus Cam
i just looked for matts response because i knew he would have it coveredOriginally posted by SS4MattI use Ardex Topaz "yellow paste wax" it's inexpensive and it's the best stuff i have found so far...that and the can has a 4th gen LT1 camaro outline on it
on the contrary I will say that this is the only paste wax i like, and i REALLY like it. Otherwise i prefer licquid.-Joel
Can either of you guys hook me up with some Ardex so I can test it?- Brian Meissen
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
You haven't seen anything, I got pages of em, lol. I've barely used any, lol.Originally posted by kammi10damn Ot where do you get all these pics
matt can probably get some through sammy b (his distributor). Thats where i got mine, im not sure if i can still buy through him or not considering i quit that job. Its only like $7 a tin.Originally posted by meissenCan either of you guys hook me up with some Ardex so I can test it?-Joel
i use a liquid 2 step wax thing, works wonderful, then i use a polish bout every 2 weeks untill its time for another wax, bout 6 months.Mods:
Ram Air Intake (CAI)
K&N Filter
Polished Throttle Body and MAF Sensor
De-screened MAF Sensor
Tightened Throttle Body Cable
Performance Button Setting Changed for Torque
160* HypterTech Thermo
Water Wetter
New Distributor, Plugs, Wires
New Water Pump
LT4 Knock Sensor
Flowmaster 40 Series Muffler
TB AirFoil
