[Detail] 2008 Lincoln MKX
  • [Detail] 2008 Lincoln MKX
    Not an F-Body, admittedly, but the procedure is the same for nearly any vehicle.
    I posted this originally back in June of 2012, so some products may have been replaced, but the idea is the same:
    Today's job was to clean up and do a full polish on a 2008 Lincoln MKX.
    Products Used:
    Optimum Car Wash
    Adam's All Purpose Cleaner
    Sonax Full Effect Wheel Cleaner
    Various Brushes
    Iron X
    Lake Country Foam Sponge
    Mother's Clay Bar
    ONR diluted for Clay Lube
    Werkstat Satin Prot
    Ultima Tire & Trim Guard Plus
    Adam's In N Out Spray
    Optimum Hyper Polish
    Optimum Microfiber Polishing Pad
    Blackfire Wet Diamond All Finish Paint Protection
    Lake Country Hydro Tech Crimson Finishing Pad
    Blackfire Midnight Sun Ivory Carnauba Wax
    Before: Car was relatively clean when dropped off
    First step was a strip wash. Wash solution was a mixture of Adam's APC and Optimum Car Wash.
    Next, Iron X was used to pull out contaminants. I suspected I would find a lot, and I was right.
    After a good rinse to get all of that putrid stuff off the paint, it was time to clay. My favorite clay is just plain old Mother's, with an ONR solution as lube. The paint was still trashed after the wash and IronX. The picture shown is after only one front fender...
    I then washed the wheels, wells, and tires using Adam's All Purpose Cleaner and Sonax Full Effect Wheel Cleaner, coupled with various brushes. The (plastic) wheels were badly stained and etched, so I just shined them up the best I could. Why a $45,000 luxury SUV comes with cheap plastic hubs is beyond me...
    Next was another quick wash to get all residue off the paint, and dried with a Cobra Supreme Guzzler.
    I like to then attack the interior while I let the drips run out and make sure everything is completely dry. The interior was vacuumed and cleaned. This plush leather and beautiful interior deserved the best, so it was dressed with Werkstat Satin Prot, which leaves a beautiful satin finish and no residue.
    This particular customer did not want the engine bay washed with water, so I cleaned it up the best I could with my ONR solution of Waterless Wash. It was then dressed with Ultima Tire & Trim Guard Plus and Adam's In N Out Spray for the tricky areas.
    After everything was clean, and I was satisfied that I wouldn't have any drips interrupting me, I moved on to polish. The paint needed very minimal correction. There were hardly any swirls, and any defects that were present were too deep/large to be fixed by polishing.
    First things first, you have to have some good tunes.
    Since I didn't need to really correct much, I chose to forgo any compounds and just use Optimum Hyper Polish to shine things up. This was coupled with an Optimum Microfiber Polishing Pad.
    Fast forward a few hours and the one-step polishing is done.
    All that was left then was to choose my weapon from my vast shelf of sealants. I'd normally go with Werkstat Acrylic Jett for a silver like this, but I was feeling a little generous and decided to go with Blackfire's two-step Wet Ice Over Fire combo. A layer of Blackfire Wet Diamond All Finish Paint Protection sealant was put down with a PC and a Crimson Finishing pad. This was followed by a layer of Blackfire Midnight Sun Carnauba Wax. The results were jaw-dropping, albeit a little hard to capture on camera.
    After the paint was nice and protected, the tires were finally completely dry and ready to be addressed. I chose to apply a tire sealant called Ultima Tire & Trim Guard Plus. This was also applied to all plastic and rubber trim. Here are some 50/50 shots with the Ultima applied to the right hand side.
    Finally, some after shots of the whole car.
    Facebook | Website
    Looks amazing!
    What do you charge for something like this? My DD REALLY needs some love.
    Sent using Tapatalk 2 on Android.
      Originally posted by sman View Post
      Looks amazing!
      Send me a PM. I can work out a deal for forum members. Check out my website for services and packages and I'll get you a price.
      Thanks!
      Sent from my Galaxy Nexus using Tapatalk 2
      Facebook | Website
        Looks really good - I really need to start spending more time detailing my cars. My poor 5th gen, daily driven, only gets touchless car washes (albeit I go through them like once a week), but although the car looks clean, it still leaves behind a "sheen" of dirt on the car if you look at it at an extreme angle.
