LS6 Heads vs. LS1 Heads Worth It?
  • LS6 Heads vs. LS1 Heads Worth It?
    I found a set of used ls6 heads with like 80k on um. Everything on um, springs, valves ect.
    Is it worth the effort and probably $500 bucks to swap out my stock ls1 heads? Any major tuneing issues or anything?
    1999 Turbo Trans Am WS6**Under Construction** Rear Mount Retired
    Haters Quote "That car wont go faster then 10.50's" My response? You Lose!!
    2015 Silverado 2500HD 6.6 Diesel
    2010 Corvette Z06
    "The SS looks like it could kick your ass if it wanted to, the WS6 looks like it's coming over to do it!"
    i would say no unless they are PP and would work well with the cam.... thats just my opioion
      stock for stock there won't be much differance. a ported ls6 will flow much more than a ported ls1 though
        buy the ls6 heads and port them
        No longer your average SS
          I wouldn't waste your money on them, much better heads out there.
            Well $500 here and a couple hundred to have them ported and you are close to a set of aftermarket heads.
            1995 TA Sold. i sure do miss it though.
            1998 Trans Am aka Winter beater
              x2, my cousin got patriot heads for his 99Z for $900 shipped to his front door.
                If your going to go with used stock heads you may as well buy some used PP heads.
                  If ya got the money port them *****es out sell the stockers youll see a noticeable about of gains especially w a cam to fit them heads
                    Buy aftermarket PP ones
