I have an 86 305 TPI motor. What type of cylinder heads could I use? Can I bolt the 350 heads on or would I gain as much by reworking the ones I have. I need to redo the seals and possibly the guides so I was maybe looking into just replacing them with better ones based on what it would cost.
Well I think you will lose low end HP with the 350 heads. But you will gain top end power. Thats what I was told when I was going to buy a set of dart heads that were off a 350.
It would be nice if you had a 350, putting 305 heads on. Then you would gain some compression.
