I just installed a Racetronix fuel kit in my Camaro with a 1995 LT1.
I have a gauge inline to my nitrous feed, right off the rail, and it reads a pretty constant 47-49psi at idle and about 42psi when priming the pump.
Are these numbers a bit too high or are they okay?
Also, when I unplug the regulator at idle it does not change, but there isn't a fuel leak from it either.
I have the Racestronix harness and -6 braided line the whole way from the pump to the rail, not sure if that would change pressure at the rail or not.
These numbers are assuming my new NX gauge is 100% accurate.
