Not really. Increasing fuel pressure can turn your smaller injectors into larger (increasing flow rate) to help dial in, but going with a full tune you shouldn't have to worry. Less stress on the pump as well.
I will say that the Racetronix setup increased the fuel pressure on my 98. It bumped it from 58 psi to well over 60 psi at idle. Closed loop compensated for this but the higher RPM allowed the regulator to maintain 58 psi.
