Originally posted by DETROITMUSCLE
View Post
Fuel pump mounting location
any reason for having the short line between the prefilter and the pump? we have both our filters off the pump ends just curious as to the benefits or any cons?Doing less with more
I had a bunch of spare fittings and line and kinda figured why not... I just didn't know if running a 12female/12female with the weight of the filter, and lines would put stress on that fitting... Probably not, seeing as there's other guys that are already running it like yours is set up... How's your guy's car coming along? and I have to ask what does the acronym nbm stand for? kinda like mqbm no one really knows unless you have it lol. Do you need any spare fittings? I've got a shit pile of themOriginally posted by DETROITMUSCLE View Postany reason for having the short line between the prefilter and the pump? we have both our filters off the pump ends just curious as to the benefits or any cons?
NBM = navy blue metallic.
the car is just on standby having issues with the fuel tank we were gonna use, they cut it up previously and somebody brazed sheetmetal in a few spots for clearance, tested it out after my feed and drain were all set and it leaks like a sive. I'm having somebody attempt to fix it and if no luck there I may have to start over with my own tank.Doing less with more
that stinks man, I hope you guys don't have to many set backs with it.. it's pretty demoralizing that's for sure, I dealt with so much crap putting mine together I was really close to parting it out... just throwing it out there gas tank renu in Swartz creek welded a sump on mine, steam cleaned it, and sand blasted it for like a $110 bucks and it turned out really nice..Originally posted by DETROITMUSCLE View PostNBM = navy blue metallic.
@DETROITMUSCLE @cOncEpT... how are you wiring your pump? Just wondering because i'm worried if I run a wire the length of the car it's gonna have too much voltage drop.. This happened with a buddies car that had to much voltage drop and it just couldn't push the amps the pump needed... wonder if throwing a big 8ga wire would work
Do you still have your battery in the front of the car?Originally posted by dawdaw View Post@DETROITMUSCLE @cOncEpT... how are you wiring your pump? Just wondering because i'm worried if I run a wire the length of the car it's gonna have too much voltage drop.. This happened with a buddies car that had to much voltage drop and it just couldn't push the amps the pump needed... wonder if throwing a big 8ga wire would work
Use the largest gauge wire you can and make sure the grounds are good.
do you think you could elaborate a little bit more? sorry my biggest weak point on a car is wiring stuff..Originally posted by c0ncEpT View PostYou could wire in a relay directly off the battery or use a power block in the very rear of the car close to the battery. All you need is the switch up front?
Don't worry I suck at wiring also.
You can wire it just like they have it set up in the picture using the factory key on signal wire or you can put a switch on pin 86 if you choose to run one.
Use 10 gauge or larger wire for everything. If your battery is in the rear your wires wont have to be long at all. By doing it this way your basically making yourself a "hotwire" harness.
[MENTION=3929]dawdaw[/MENTION] do you have any good pics of your tank after they welded on the sump and cleaned it up? Looking like I may have to start over here...Doing less with more
awesome thank you, simple enough for me.Originally posted by c0ncEpT View PostDon't worry I suck at wiring also.
[ATTACH=CONFIG]50764[/ATTACH]
these are the only ones I have on my phone.. If you need any more just let me know, it's a 1/2NPT thread on the sump, I used a 1/2 to -12 an fitting that I reamed out to the inside diameter of the -12an hose so there was no restriction. My tank was a little rusty, but it was pretty nasty inside... It looked brand new when I got it back.
