bbk shorties with stock y??? can it happen??
  • bbk shorties with stock y??? can it happen??
    Picked up a set of BBK shorties from steve, wondering if
    I can use the stock y if i change the bolt flange on the y
    To a 2 bolt setup?
    Only reason i ask is im anxious to put these on.
    And also i have a 93 so what do i do with the passenger
    Header with egr? Looks like i have a egr tube coming from my
    Intake. Do i block this off? And how do i block it off?
    No sir it will not work nor will you be happy you to go on to summit site and get the the BBk y pipe and extra long pigtails egr connection kit everything wouldn't cost you more then 80 bucks with clamps and while your at it get a alp loud mouth 2 boom your in the game and you can put this stuff on your self
    GODSPEED and PEGASUS now you F$&K'IN with a HIGHERPOWER!!!sigpic
      I can grab the y pipe from steve. I was just curious. Picking up the y pipe
      Monday from him.
        Yes get the y pipe
          Also what do i do about the egr stuff? I know 1993s are weird about it
            If the headers have block off plates then block them off and then delete the code for them if not then just deter the code and you are good to go but I only know that for 1998 to 2002 cars
              Ill have to find some block off plates,
              Or a egr tube from a 94+ to use on my 93
