Pro-filer 23* SBC heads.
Will flow over 300cfm as cast.
With CNC work will flow over 400cfm.
CFM isn't everything when talking about a set of heads but good numbers.
Best part is they cost 475 a head.
So 900 for a pair.
It costs between 300-400 to convert to reverse cooling.
So total of 1200 - 1300 to flow 300cfm out of the box.
AFRs will flow the same but for over 2000 bucks. Also they are already fully machined I heard.
Now TFS 23* from AI will flow over 400 for 2500 bucks.
AI 200cc LT1 heads will flow almost 300 for 1775 and thats the max for the heads.
Also converting to SBC heads opens up a ton of manifolds.
They are also drilled for both center and rail bolt valve covers. So you can use stock valvecovers or SBC valvecovers.
Here is the lift tested as cast.
Lift No. 1 No. 2
0.2000 143.0 96.2
0.3000 204.3 150.1
0.4000 249.7 178.0
0.5000 284.2 198.8
0.6000 299.6 211.0
0.7000 299.6 218.1
0.8000 301.9 221.3
0.9000 301.9 222.9
1.0000 299.6 222.9
Average: 264.9 191.0
For 1500 bucks (valvetrain added) you will have heads that will perform just as well as AI 200cc heads plus be able to machine them to flow as much as TSF 21* 245cc heads.
So 900 for a pair.
Lift No. 1 No. 2
0.2000 143.0 96.2
0.3000 204.3 150.1
0.4000 249.7 178.0
0.5000 284.2 198.8
0.6000 299.6 211.0
0.7000 299.6 218.1
0.8000 301.9 221.3
0.9000 301.9 222.9
1.0000 299.6 222.9
