Originally posted by CollinsAutomotive
Megasquirt II ECM
We are running the actual LT1 OBD2 box. if you wanted to run boost on a factory ECM for a 3100 with DIS you would have to use a 7730 ecm with 8F TGP code which is DIS compatiable.Originally posted by MattODoomWhat code are you running on that? With these older ECMs in order to take boost you have to either get a '730 with a code hack and 2bar MAP sensor and run that or get a syclone ECM (forgot part number?) and use that mask and bin.
I'm the Rob that Matt mentioned that has the megasquirt II. I have it assembled with a labled wiring harness, fuel pump re-wire harness, and gm air and coolant temp sensors. Shoot me a pm if your looking for one. Good luck on your project!
InActive Member
- May 4th, 2005
- 68
- Eric Malek
- 82 Trans Am
- Grass Lake, MI
- Marketing @ Dynomax Performance Exhaust
I have been following the Megasquirt ECM's for a while and they seem to work quite well, especially for the price! The advantage would be tuneability without having to dink with those dang chips.sigpic
