When is a bigger TB and MAF needed? Well lets go into the numbers here.
A 48mm stock TB flows 783cfm without airfoil.
821.9cfm with an airfoil.
Stock LT1 MAF will flow 719cfm with the screen removed (do not recommend).
So lets crunch some numbers.
The formula we are going to calculate engine CFM with is as follows.
So lets take a LT1.
Lets say your car is a beast and is 100% VE.
Just some number crunching for thought. Cause bigger isn't always better.
CI x RPM x .5 x VE / 1728
So lets take a LT1.
350 x 6000 x .5 x .85 / 1728
= ~516cfm
So as we can see, a stock LT1 at 6000rpm will consume roughly 516cfm. The stock TB will flow 783cfm, still higher. The stock MAF will flow I'd say with the screens in probably +600 so still not a restriction. = ~516cfm
350 x 7000 x .5 x 1 / 1728
= ~709cfm
At the PCM limit of 7000 and a perfect VE which is not going to happen without boost, a LT1 will consume ~709cfm. So at this point, the MAF would become a restriction with the screens in.= ~709cfm
