ARP Head Studs?
  • ARP Head Studs?
    Has anyone ever installed these? Im trying to figure out if i use any thread locker or Teflon tape on them?
    Thanks,
    Nick
    tape shouldnt be used anywhere in an engine
    if they go into coolant maybe paste. no thread lock because the stud is left loose (not bottomed) and must turn when tightening
      Thanks Man...also how do i know how far i turn them down into the block?
        normally its like 1/4 turn from being bottomed out.
        they should turn all the way in by hand.
          Thanks man ill see how everything goes and be posting pics on my project thread soon
            ARP recommends their specific lube on the bolts, I just broke down and bought a big tube. If not they recommend using motor oil, not loctite.
              I heard that they do for putting the bolts on...but i was trying to find something to lock the studs in place.
                FWIW:
                I installed mine (3800) using Teflon Paste on the block end, and tightened to 11 ft# (IIRC) then used their moly lube on the head side
                2004 Impala LS (DD)
                1997 Firebird 3800 (current project)
                http://www.mifbody.com/vbulletin/sho...oject-FireTurd
                www.hellfiremotorsports.com/garage
