So after i put my new headers in i keep getting a tapping sound from under the car from the y-pipe directly after the drivers side header. It comes with a dip in the y-pipe for that issue but it still tapps it...do they make anything like a pad or anything that will make the tapping go away or at least not be so annoying?
thats is why you pay a bit more for quality headers and not the ebay hit or miss junk. The best way to cure it is try and actually bend the y-pipe a bit or you can try to jam a piece of rubber hose in there or a clamp could work as Vinnie mentioned.
Thanks for pointing out the obvious Jeff lol. I think i got it figured out i used some exhaust wrap.
This is a very common problem. first, heat up the header with a torch ahead of the collector and hang your weight on it. You might be able to massage it down some.
If that doesnt work, do what i did and take a floor jack to your floor board. bend it up a tad, but only a half inch or so. dont do any more than that or you will notice it in the car. It may sound ghetto but it works.
That is a good idea but i think im going to try the wrap first and see if it helps if not i guess i will be doing one of those. Thats what i get for getting cheapys
i doubt they are cheapies. its a common problem with MOST headers for LT1s. The only ones i know of that dont have that problem are Hooker/Jet Hots, and thats because they hang a good 2" lower - which you wouldnt be any better off with. I had the same issue with pacesetters and that is considered a trusted header.
